> 150k mile tune-up, What parts do I need
post Nov 16, 2010 - 2:56 PM
captb
Joined Sep 23, '08
From Hawaii
Hi all. So my car is nearing 150k miles and the water pump and none of the belts have been replaced that I know of. Goals for this tune-up is preventative maintenance as well as get rid of small oil leak. I did some research and here is a list of parts that i would like replaced. Is there seals/anything i am missing that i might as well replace when doing this. also, i need some help finding the part numbers for some of the items.
Parts are for '94 GT coupe:
Timing Belt (13568-09041)
Water Pump (19100-79185-83)
Thermostat (90916-03046)
Thermostat Gasket (16325-63011)
Idler Pulley (13503-63011)
Tensioner Pulley (13505-74011)
Alternator Belt (99365-81110-78)
Power Steering Belt (99363-90760-83)
Distributer O-ring (90099-14091)
Distributer Rotor (19102-11370)
... and here are the parts i need help sourcing
Spark Plug Tube Gaskets (??)
Cam Seals (??)
Oil Pump Seal/Front Pump Seal (??)
PCV Valve (??)
AC Belt (??)
And these parts are only a few months old
-Valve Cover Gasket
-Distributer Cap
-Spark plugs
-Spark plug wires
Thanks,
-Joel
post Nov 17, 2010 - 12:47 AM
Arsaces
Joined Oct 7, '10
When I did mine I bought this:
http://shop.advanceautoparts.com/webapp/wc...S_1002202528___
I had the water pump, timing belt, and that seal replaced which fixed all my oil leaks (Note that you also need to buy 052-3691 with it, I forgot to do this, shop I took it to had it, but they charge much more of course).
As for the Spark Plug tube gasket you want to buy a valve cover gasket kit, if you are asking for what I think you are asking for that is:
http://shop.advanceautoparts.com/webapp/wc...S_1002131610___
Camshaft Seal:
http://shop.advanceautoparts.com/webapp/wc...1_1002122811___
PCV:
http://shop.advanceautoparts.com/webapp/wc...S_1073935114___
comes up when I searched it, but with the pcv all you gotta do is shake it, if it makes noise it is good.
AC Belt, you probably did not find this one because they most likely listed it as alternator belt:
http://shop.advanceautoparts.com/webapp/wc...S_1148494885___
I do not know if the part numbers that you listed was for buying it from Toyota or not, but those are the ones I came up with, hope it helps.
post Nov 17, 2010 - 3:14 AM
captb
Joined Sep 23, '08
From Hawaii
Arsaces, You are awesome. That is exactly what i was looking for. I like that they have pictures of the items to actually see if that is the part i need. And there prices arent bad either. and yes, the part numbers are for oem toyota because I was planning to use the 6gc discount from partznet.com.
post Nov 17, 2010 - 4:27 AM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (captb @ Nov 17, 2010 - 4:14 AM) *
fun part!
post Nov 17, 2010 - 10:23 AM
Arsaces
Joined Oct 7, '10
Rofl, I took it all to a local shop and had them do it. 500 bucks for labor, but I know it is done right (I trust this shop), warrantied, and I was able to be at work while it was getting fixed biggrin.gif
post Nov 17, 2010 - 2:43 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Joel, Give me a call. I can get all those parts cheaper than anyone can get them. I already have the a/c and pwr steering belt at my house.
post Nov 17, 2010 - 3:50 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
While your changing all that, might as well change the oil pump too. Might help in the long run.
post Nov 17, 2010 - 3:56 PM
MrNate
Joined Nov 15, '10
From MA
True, my last car was a camry with the 5sfe in it and I had 175k or so on the motor which was driven with respect and TLC. The oil pump was worn out because my pressure was around 45 I think at highway speed (65 or so) and after it went up to high 50s...60 on a cold day with synthetic oil.
post Nov 19, 2010 - 1:40 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (captb @ Nov 16, 2010 - 9:56 AM) *
Timing Belt (13568-09041)Water Pump (19100-79185-83)
Tensioner Pulley (13505-74011)Alternator Belt (99365-81110-78)
Cam Seals (??)
PCV Valve (??)
-Valve Cover Gasket
-Distributer Cap
-Spark plugs
-Spark plug wires
Thanks,
-Joel
so how did you like my price wink.gif i told you i hook up CCO people
post Nov 19, 2010 - 8:20 AM
captb
Joined Sep 23, '08
From Hawaii
post Nov 19, 2010 - 12:15 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i believe that the water pump comes with a gasket kit and the thermostat gasket is in that kit.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 19, 2010 - 12:43 PM
QUOTE (Smaay @ Nov 19, 2010 - 12:15 PM) *
Depends on how you order it. You can get the complete water pump, or just the main part without the water pump cover. The complete one comes with all the gaskets.
Lo-Fi Version Time is now: November 25th, 2024 - 11:44 PM
