> Both low beam went out
post Nov 16, 2010 - 4:54 PM
rheyx
Joined Apr 22, '08
Both of my low beam went out , i was thinking its the fuse because theres no way both will go bad at the same time . Fuses are all good . any idea what might be the problem?
This post has been edited by rheyx: Nov 16, 2010 - 4:55 PM
post Nov 16, 2010 - 5:30 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Maybe a wire or something got loose?
June '12 COTM
'95 AT200
post Nov 16, 2010 - 5:47 PM
mkernz22
Joined May 10, '10
From MA
it wouldn't be the fuse, try replacing the relay in the engine bay
post Nov 16, 2010 - 7:54 PM
rheyx
Joined Apr 22, '08
QUOTE (mkernz22 @ Nov 16, 2010 - 6:47 PM) *
i tried pulling out the relay and both high and low went out , is it possible that only the low beam part is bad? if relay will go bad both high and low should go bad right? theres only one relay for the high and low right?
This post has been edited by rheyx: Nov 16, 2010 - 7:56 PM
post Nov 16, 2010 - 7:57 PM
rheyx
Joined Apr 22, '08
QUOTE (HectortheRican @ Nov 16, 2010 - 6:30 PM) *
post Nov 16, 2010 - 9:23 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
Here's the trouble shooting guide from the Toyota Factory Manual, but mine only covers US & Canada. The codes to the right of the trouble shoot guide show a detailed breakdown of the system if you need further detail. It sounds like the control switch from your description.
post Nov 16, 2010 - 9:49 PM
rheyx
Joined Apr 22, '08
QUOTE (pyeatts @ Nov 16, 2010 - 10:23 PM) *
wow very useful, ill check on that.
post Nov 17, 2010 - 8:22 AM
SleekCelica
Joined Mar 28, '10
From Columbia, South Carolina
Check the bulbs. Don't overlook something that simple before you go prodding around with circuits wink.gif
1994 Celica GT, coupe, 5 speed.
Front strut brace, cherrybomb glasspack, intake.
post Nov 17, 2010 - 1:26 PM
rheyx
Joined Apr 22, '08
QUOTE (SleekCelica @ Nov 17, 2010 - 8:22 AM) *
Yes sir i did .. but its impossible to have 2 bulbs goin bad at the same time.
post Nov 17, 2010 - 7:01 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Lets not say impossible, rare yeah. But usually two lights going at once, start with their most common point and go backwards.
Lo-Fi Version Time is now: January 9th, 2025 - 8:15 AM
