3 Pages V  < 1 2 3 >
> So I Hit Another Car
post Dec 7, 2010 - 1:26 AM
brk34
Joined Jan 20, '08
Update the airbags and center sensor came. Glass guy is coming next Thursday. I may take some pictures but it's way to cold to work outside and I have finals.
post Dec 28, 2010 - 8:38 PM
brk34
Joined Jan 20, '08
Ok so far I am sourcing the bolts that I striped when removing the sensors. The car is burred in snow so I'm waiting until the snow melts before starting on removing the center sensor and other interior stuff. I will take some more pictures.
I have one question though, are the bolts for the airbag on the drivers side t-40?
post Dec 30, 2010 - 8:39 PM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
a little off topic, kinda, but... i love your thread title. hope to see her up and rolling again soon.
post Dec 31, 2010 - 2:20 PM
brk34
Joined Jan 20, '08
It was very warm today so here are some pictures. I'm Still working on taking apart the interior and I stopped because I need a steering wheel puller. I'm thinking of using autozone's loan-a-tool program since I only need the puller once. How should i get the steering wheel nut loose it seems to be stuck on quite good?
New glass is in.
Inside of the dash. There were strange splices on the alarm wiring.
I took apart some of the center dash area.
And I got the driver side airbag out.
post Dec 31, 2010 - 4:34 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Breaker bar my friend.
94 Celica gt white (sold)
post Dec 31, 2010 - 4:39 PM
brk34
Joined Jan 20, '08
Sounds good I will borrow a large one and give it a shot.
post Jan 3, 2011 - 7:49 PM
brk34
Joined Jan 20, '08
I have another question. How do I remove the A/C control module? I'm not sure how to remove the control cables I did get the steering wheel bolt loose and will soon remove the wheel.
This post has been edited by brk34: Jan 3, 2011 - 7:50 PM
post Jan 4, 2011 - 1:00 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Theres a cable on the firewall where the heater control valve is. Just unhook from HCV and pull out the climate control unit.
post Jan 4, 2011 - 5:44 PM
brk34
Joined Jan 20, '08
That worked great Thanks a lot. Can I use the 94 clock spring on my 97? The clock spring came with the airbags. It looks like no since the 94 has a lead on both end and the 97 has a lead on only the end that connects to the air bag.
post Jan 16, 2011 - 5:12 PM
brk34
Joined Jan 20, '08
I'm putting the passenger airbag in and I noticed that the clips are damaged. This picture shows what I'm talking about. What should I do?
post Mar 12, 2011 - 7:28 PM
brk34
Joined Jan 20, '08
Weather was great today. I managed to get all of the HVAC ducts and the wiring loom is attached. I will have some pictures soon. I think the next step is to bolt the dash down and install the gauge cluster.
post Mar 13, 2011 - 6:08 PM
brk34
Joined Jan 20, '08
Got the car back together enough to get it started. Couldn't get it started until I connected the alarm. Now I need to buy a hood and I will have all of the parts.
post Apr 2, 2011 - 2:47 PM
brk34
Joined Jan 20, '08
Bending the sheet metal back and hopefully pictures soon.
post Apr 2, 2011 - 7:05 PM
post May 1, 2011 - 9:23 PM
brk34
Joined Jan 20, '08
Got the air bag system back together. But the light came on. Code 54. I'm following the test procedure to short the connectors and clear the code etc. However it seem like I haven't cleared the code yet. I'm having trouble with the shoring of the connector under the hood. Also I think that I need to short the airbag harness connectors with thinner pieces of wire.
post May 24, 2011 - 3:17 PM
brk34
Joined Jan 20, '08
Ok now that school is over I'm working on it again. No luck with resetting the code I'm beginning to suspect that the center sensor is bad. Does anyone have tips on getting the codes to clear?
This post has been edited by brk34: May 24, 2011 - 3:25 PM
post May 25, 2011 - 3:32 PM
mkernz22
Joined May 10, '10
From MA
you need to replace the airbag ECU after you get into an accident. or you could just clear it by unplugging it lol
This post has been edited by mkernz22: May 25, 2011 - 3:32 PM
post May 25, 2011 - 10:34 PM
brk34
Joined Jan 20, '08
I did replace it but for some reason it has a code. Maybe I'm not following the clearing procedure correctly.
post May 28, 2011 - 8:41 PM
brk34
Joined Jan 20, '08
I got the codes cleared and it's picture time. But now the darned thing won't shift out of park unless I use the override.
post Jun 3, 2011 - 7:09 PM
brk34
Joined Jan 20, '08
I found the disconnected connector it was the grey one behind on the ignition switch. However now it won't start. It cranks but i can't hear the fuel pump running. I plan to look at the fuses and relays. Is there a similar relay that I can swap?
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: February 18th, 2025 - 8:34 PM
