> Noises after lowering!, Help!!!!!!!!!!!!!&
post Nov 27, 2003 - 3:58 PM
speedracer_2020
Joined Jun 22, '03
From Toronto, Ontario, Canada
So I lowered my car after a while.. just pulled the factory struts / whatever out and replaced them with with KYB Gr2's and Eibach Sportline's
There's this noise. I'm sure all you pros know what i'm talking about.
Is there some add-on kit that I should added .. or some dampener or something that I forgot to install that was extra to what I listed?! Lemme know
Thanks a million
Shaun
post Nov 28, 2003 - 12:52 AM
Junior
Joined May 5, '03
From Toronto
could be bushings if you're lucky. but probably top mounts, just because they cost more.
post Nov 28, 2003 - 1:21 AM
What does this noise sound like?
post Nov 28, 2003 - 4:28 PM
speedracer_2020
Joined Jun 22, '03
Kinda like a knock knock knock.. only heard at low speeds...
and .. mounts? Where can I get ones that'll hit the 1.5" Eibach Sportline drop? Do the factory ones work fine?
And what type of bushings?
Thanks guys.
Shaun
post Nov 28, 2003 - 4:38 PM
CelicaGuy97
Joined Jun 15, '03
From lexington, north carolina
my car did this until i put a camber kit on it
post Nov 28, 2003 - 4:46 PM
Jussimple
Joined Jan 3, '03
From South Carolina
Most likely your sway bar links. Mine did it for awhile till I took her to the shop and found out what it was. Easy fix with some new links or new sway bars.
J
This post has been edited by Jussimple: Nov 28, 2003 - 4:47 PM
post Nov 28, 2003 - 7:58 PM
JKceli
Joined Apr 6, '03
From Gainesville, FL
There should really be a sticky for this. It seems to be the #1 complaint whenever you lower your car.
It could be:
1. Bushings
2. Loose sway bar linkages
3. The springs may not be properly set
Refer to this link for more detailed explanations
Clunking
Hope it helps.
Jordan
post Nov 28, 2003 - 8:34 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Im going to say the links, same thing with me.... did anyone find a place to buy them cheap??
post Dec 1, 2003 - 6:10 PM
speedracer_2020
Joined Jun 22, '03
Thanks guys! Much appreciated!
So.. the sway bar links? HOw exactly to I get around to fixing these? I'll be taking it into the shop when I get my drive axels replaced at the end of the month soooooo.. what should I say to them..
Thanks again!!!
Shaun
post Dec 1, 2003 - 6:38 PM
SpedToe169
From Dallas, Tx
This is obviously but often overlooked....make sure everything is tight!!! Like everybody said, sway bar end links are an obvious one. Also make sure you check the upper spring perches. They will move unless really tight.
Lo-Fi Version Time is now: February 20th, 2025 - 1:55 AM
