> Oil Cooler
post Nov 19, 2010 - 6:23 AM
fgvillegas
Joined Mar 22, '10
From Philippines
i recently shift to a standalone ecu and have my cams adjusted to provide maximum power and torque. i was again happy witht the dyno result. however, i noticed that my water and oil temperature is higher than usual so i'm planning to install an oil cooler to ease up the heat. i'm not sure, though, if an oil cooler without a thermostat is sufficient. the one with thermostat is so expensive that's why i'm opting for the other one.
my question is, would it be difficult to reach the normal operating temp if there is no thermostat in the oil cooler?
thanks.
post Nov 19, 2010 - 12:10 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you will have no problems with a normal oil cooler, im curious why your normal operating temperatures have risen.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 20, 2010 - 1:44 AM
fgvillegas
Joined Mar 22, '10
From Philippines
QUOTE (Smaay @ Nov 19, 2010 - 1:10 PM) *
thanks. does size matter? i'm just planning to get a smaller one.
the cams were set more aggressively.
Lo-Fi Version Time is now: January 10th, 2025 - 5:27 PM
