need help, speed sensor for my 4 wheel steer gen 6 |
Nov 22, 2010 - 9:38 PM |
Enthusiast Joined Nov 18, '10 From dundee scotland Currently Offline Reputation: 0 (0%) |
needing help to locate a speed sensor for my 4ws 97 gen6 can anyone help
Dec 8, 2010 - 1:56 AM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
I'm not 100% sure because I haven't tested it myself but acording to the schematic (for the 2WS GT4 but should be the same) it appears the vss signal can be found behind the gauge cluster and is a blue/black wire.....position 8 of the connector. If that one doesn't work then it may be a blue one at pos 14
This post has been edited by schmooot: Dec 8, 2010 - 1:57 AM -------------------- ST205 Crew represent
Challenge Accepted |
Mar 14, 2011 - 10:42 AM |
I'm not 100% sure because I haven't tested it myself but acording to the schematic (for the 2WS GT4 but should be the same) it appears the vss signal can be found behind the gauge cluster and is a blue/black wire.....position 8 of the connector. If that one doesn't work then it may be a blue one at pos 14 CHEERS BUD |
Lo-Fi Version | Time is now: November 27th, 2024 - 2:53 AM |
