7gen steering wheel airbag on 6gen |
Nov 23, 2010 - 2:05 AM |
Enthusiast Joined Oct 24, '09 From New Zealand Currently Offline Reputation: 0 (0%) |
hi, just wondering if the 7gen air bag can be installed on 6gen? need mod on the wiring?
Nov 28, 2010 - 12:16 AM |
bump
im going to get a 7gen set which incl steering wheel and air bag , just wondering if the air bag need some mod to connect to my 6gen |
Nov 28, 2010 - 12:37 AM |
there should be a sticky somewhere on here on modding it
Nov 29, 2010 - 2:59 PM |
yes it can be done, i havent written an install guide yet. you will have to cut and soldier the airbag wires because the plugs are different, but its a no brainer. you will use the 6th gen cruise control switch.
yes it can be done, i havent written an install guide yet. you will have to cut and soldier the airbag wires because the plugs are different, but its a no brainer. you will use the 6th gen cruise control switch. -------------------- 2001 Celica GT-S Turbo
Nov 29, 2010 - 6:58 PM |
Enthusiast Joined Aug 29, '08 From AZ, US Currently Offline Reputation: 21 (100%) |
Dec 20, 2010 - 1:22 AM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
if I am are replacing my oem steering wheel with the 7gc wheel...how do i know how to put the 7gc steering wheel on in the right location since i won't be using the old steering wheel anymore? how did you do it and how do you know? (i am suppose to make a marking on the steering wheel, but if it's not the same steering wheel, then the alignment would be off correct?)
thanks for your help in advance. |
Dec 20, 2010 - 8:53 AM |
^ You just have to make sure your steering wheel (and your wheels) are perfectly straight.
Just before you put the airbag back on, go for a quick test drive to make sure it's straight, if the steering wheel isn't then readjust it. |
Dec 20, 2010 - 2:02 PM |
thanks.
Lo-Fi Version | Time is now: November 26th, 2024 - 9:22 PM |
