> wiring diagrams for every celica year, dug into my notes and made this write up for alarms/ remote starters
post Nov 24, 2010 - 4:27 AM
deathdoakill
Joined Jul 19, '05
From San Antonio
Well guys ive been getting alot of questions for wiring diagrams for remote starters and alrams so i figured id post a useful set of wiring diagrams to those of you who need it if you have any questions let me know im always glad to help
Toyota
MODEL YEAR(S)
CELICA 1987 -1989
KEY T-HARNESS IMMOBILIZER
N/A N/A N/A
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) or BLACK RED (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLUE/RED (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) LIGHT GREEN/BLACK (-) @ STEERING COLUMN HARNESS
PARKING LIGHTS ( + ) DARK GREEN (+) IN DRIVERS KICK PANEL
POWER LOCK BLUE/BLACK (TYPE B) IN EITHER KICK PANEL
POWER UNLOCK BLUE and GREEN (TYPE B) Use both, See NOTE *1 IN EITHER KICK PANEL
DOOR TRIGGER RED/WHITE (-) @ FUSEBOX
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN GREEN (-) @ STEERING COLUMN HARNESS
TACH BLACK (-) @ IGNITER
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 the UNLOCK connection, requires using BOTH wires, you must DIODE ISOLATE when connecting, See DAIGRAM.
TOYOTA
MODEL YEAR(S)
CELICA 1990 -1993
N/A N/A N/A
PART COLOR LOCATION
STARTER 2
IGNITION 1 BLUE/RED (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 GRAY (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) LIGHT GREEN (-) @ STEERING COLUMN HARNESS
POWER LOCK BLUE/BLACK (TYPE B) IN DRIVERS KICK PANEL
POWER UNLOCK BLUE and GREEN (TYPE B) Use both, See NOTE *1 IN DRIVERS KICK PANEL
TRUNK RELEASE N/A
TACH BLACK or WHITE/BLUE @ CHECK CONNECTOR See NOTE *2
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 WHEN CONNECTING FOR UNLOCK, YOU MUST USE BOTH WIRES AND DIODE ISOLATE, to connect, See DIAGRAM NOTE *2 THE CHECK CONNECTOR IS LOCATED BEHIND THE DRIVERS STRUT TOWER
TOYOTA
MODEL YEAR(S)
CELICA 1994 -1996
N/A N/A N/A
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) and BLACK/RED (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 BLUE/RED (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
KEYSENSE N/A
PARKING LIGHTS ( + ) DARK GREEN (+) @ DIMMER SWITCH
POWER LOCK BLUE/BLACK (TYPE B) @ LOCK MODULE, RIGHT of STEERING COLUMN
POWER UNLOCK BLUE and GREEN (TYPE B) Use both, See NOTE *1 @ LOCK MODULE, RIGHT of STEERING COLUMN
DOOR TRIGGER RED/WHITE (-) IN DRIVERS KICK PANEL
TRUNK RELEASE N/A
TACH GRAY (-) @ CHECK CONNECTOR, See NOTE *2
BRAKE GREEN/WHITE (+) IN DRIVERS KICK PANEL
ANTI-THEFT N/A
EXTRA INFORMATION
TOYOTA
MODEL YEAR(S)
CELICA 1997 -1999
N/A N/A N/A
PART COLOR LOCATION
STARTER 2 N/A
IGNITION 1 BLACK (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
KEYSENSE N/A
DOMELIGHT SUPERVISION USE DOOR TRIGGER,Requires Part #775 Relay
TRUNK RELEASE N/A
TACH GRAY (-) @ CHECK CONNECTOR, See NOTE *3
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 WHEN CONNECTING FOR UNLOCK, YOU MUST USE BOTH WIRES AND DIODE ISOLATE, to connect, See DIAGRAM NOTE *2 THE CHECK CONNECTOR IS LOCATED BEHIND THE DRIVERS STRUT TOWER. ON THE 2.2L ENGINE GO TO THE IGNITOR ON THE REAR DRIVERS SIDE OF THE ENGINE.
TOYOTA
MODEL YEAR(S)
CELICA 2000 -2004
TOY KEY-1 TOY-4 N/A
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) IGNITON SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/ORANGE (+) See NOTE *1 IGNITION SWITCH HARNESS, See DIAGRAM
IGNITION 2 BLUE/RED (+) See NOTE *2 IGNITON SWITCH HARNESS
IGNITION 3 N/A
KEYSENSE N/A
PARKING LIGHTS ( + ) DO NOT USE!!!
POWER LOCK BROWN (TYPE B) PASSENGER DOOR HARNESS or BCM, See NOTE *3
POWER UNLOCK YELLOW/BLACK (TYPE B) PASSENGER DOOR HARNESS or BCM, See NOTE *3
TRUNK RELEASE N/A
HORN BLUE/BLACK (-) @ STEERING COLUMN HARNESS or BCM, See NOTE *3
TACH BROWN/WHITE (-) @ REAR OF INSTRUMENT CLUSTER
FACTORY ALARM DISARM DISARMS WITH UNLOCK
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 this vehicle will require an extra relay Part #775, to isolate the IGNITION #1 wire, to connect, See DIAGRAM NOTE *2 THERE ARE (2) BLUE/RED (+) WIRES IN THE IGNITION HARNESS. THE CORRECT IGNITION WIRE IS THE HEAVIER GAUGE WIRE AND IT HAS ONE SILVER HASH MARK .THE WRONG WIRE HAS (2) SILVER HASH MARKS. NOTE *3 the BCM (Body Control Module) is located to the RIGHT side of the RADIO, you must remove the RADIO to access.
TOYOTA
MODEL YEAR(S)
CELICA 2005 -
N/A TOY-4 N/A
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 2 BLUE/RED (+) See NOTE *2 IGNITION SWITCH HARNESS
IGNITION 3 N/A
KEYSENSE YELLOW (-) IGNITION SWITCH HARNESS or BECU, TOP PLUG, PIN 9, See NOTE *3
PARKING LIGHTS ( - ) LIGHT GREEN (-) @ HEADLIGHT SWITCH or BECU, TOP Plug, Pin 5, See NOTE *3
PARKING LIGHTS ( + ) GREEN (+) @ BACK of FUSEBOX, 13-PIN PLUG
POWER LOCK BROWN (TYPE B) See NOTE *4 IN DRIVERS KICK PANEL or 20-PIN PLUG, BACK OF FUSE BOX
POWER UNLOCK YELLOW/BLACK (TYPE B) (Requires Double Pulse) See NOTE *4 IN DRIVERS KICK PANEL or BECU, TOP PLUG, PIN 25
DOOR TRIGGER RED/YELLOW (-) and RED (-) Use both, See NOTE *5 @ BECU, BOTTOM PLUG, PINS 20 and 21, See NOTE *1
DOMELIGHT SUPERVISION RED/WHITE (-), Requires Part #775 Relay IN DRIVERS KICK PANEL or BECU, TOP PLUG, PIN 10, See NOTE *3
TRUNK RELEASE N/A
HORN BLUE/BLACK (-) @ BECU, TOP PLUG, PIN 14, See NOTE *3
TACH BROWN/WHITE @ BACK of FUSEBOX, 20-PIN PLUG, PIN 4
BRAKE GREEN/WHITE (+) @ BACK of FUSEBOX, 13-PIN PLUG
FACTORY ALARM DISARM DISARMS with KEYSENSE wire
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 this vehicle will require an extra relay Part #775 to isolate the IGNITION #2 wire, to connect, See DIAGRAM NOTE *2 THERE ARE 2 BLUE/RED (+) WIRES IN THE IGNITION HARNESS. THE CORRECT IGNITION WIRE IS THE HEAVIER GUAGE WIRE AND IT HAS (1) SILVER HASH MARK .THE WRONG WIRE HAS 2 SILVER HASH MARKS. NOTE *3 the BECU (Body Electronic Control Unit) is attached to the back of the FUSEBOX, you must remove the RADIO to access. NOTE *4 the LOCK and UNLOCK wires will only TEST while turning the key in the DRIVERS DOOR KEY CYLINDER. NOTE *5 the DRIVERS DOOR is a RED/YELLOW(-) and the PASSENGER DOOR is a RED(-) when connecting to an ALARM System, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM.
this is wut it referes to when it says see diagram for the year 2005
OK These are all the wiring and locations for them for all models if you notice anything that might not be 100% let me know and ill correct it it took me a long time to do this and i might of mixed up a pic or two but i doubt it alll the witing info and locations are 100% though
post Dec 2, 2010 - 1:07 AM
chacha
Joined Dec 29, '05
From So-Cal
very cool...thanks!
post Dec 2, 2010 - 9:10 AM
mkernz22
Joined May 10, '10
From MA
awesome man!
STICKY!
Lo-Fi Version Time is now: December 4th, 2024 - 6:06 PM
