C-One Motorsports tuned ecu for st-205, Testing inside! |
Nov 24, 2010 - 8:50 AM |
Hey guys, Jim recently aquired a C-One Motorsports tuned ecu, that he is planning on using for now in his 205 swapped alltrac.
Since there isnt an AWD dyno around me, I installed it in Jenns car, first to see if it worked, and if it did, to test it some, and hopfully hit the dyno to compare it back to back VS a stock ECU. heres a link to the c-one site in english: http://www.microsofttranslator.com/BV.aspx...ARTS%2Fecu.html its a very simple deal to install, simply unplug your ecu, and plug this one in. the first couple days, i didnt notice any big diffrences, boost cut is raised (or removed, i havent hit over 20psi) speed cut as well. then yesterday, i got a little settled in with it, and took a good ride. its definetly faster, especially after 5K rpm, and has a raised (or removed, again, not sure yet) rev limiter. i hit 7800rpm in 4th, and didnt hit the limiter, just didnt have the balls to keep my foot in it on the road. im hoping to get to the dyno within the next week or 2, and do some back to back testing VS the stock ECU. if i had to guess right now, i would say its prolly a 15 or 20whp gain, and a good bump in tq as well, hopfully we'll find out for sure here soon enough! more to come! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Nov 24, 2010 - 9:41 AM |
im assuming that Jim used the ST205 tranny. If for some reason he used the ST185 tranny you could put it in @WD mode for the dyno...but im sure you both are well aware of that.
Nov 24, 2010 - 9:50 AM |
yea, he is using a 205wrc tranny.
Lo-Fi Version | Time is now: November 28th, 2024 - 12:40 AM |
