fs: 3sgte fully rebuild in socal my spare engine |
Nov 24, 2010 - 7:33 PM |
Enthusiast Joined May 16, '10 From california Currently Offline Reputation: 1 (100%) |
im finished with my 5sgte build
i was keeping this as a spare but my supras motor blew so i need the funds to build my engine im not a shop>>>>> why settle for a used engine you dont know the actual mileage this has 0 miles..... new valve cover seal head is ported cleaned and decked new cam seal new head bolts new head gasket block was honed new piston rings new bearings new water pump new oil pump new tensioner new timing belt new oilseal front and rear $1700 if you buy the engine or $1500 plus your old engine 714 574 0555 located in bellflower i can also install but prefer to just sell the engine... no negative feedbacks please or stupid questions call me for more info DSCF0152 by bzebern, on Flickr DSCF0151 by bzebern, on Flickr DSCF0150 by bzebern, on Flickr |
Nov 28, 2010 - 4:08 PM |
lowered price $1200
need to sell |
Nov 29, 2010 - 3:08 PM |
are the pistons OEM or aftermarket billit? stock bore? head bolts or studs? im VERY VERY interested.
This post has been edited by Smaay: Nov 29, 2010 - 3:09 PM -------------------- 2001 Celica GT-S Turbo
Nov 30, 2010 - 12:36 AM |
Nov 30, 2010 - 7:13 PM |
why stock pistons and 5M? rings? are you using stock oversized pistons?
Nov 30, 2010 - 9:26 PM |
Nov 30, 2010 - 9:33 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
Usually when you overbore an engine you'd get stronger pistons.
Dec 1, 2010 - 10:04 AM |
so you had the block bored over 1MM? and you have 1MM oversized rights? did you put in 1MM oversized pistons. im trying to figure out what was done. cause if you didnt, that engine needs to come apart. what is the ring gap set to?
Dec 1, 2010 - 6:08 PM |
Dec 1, 2010 - 6:14 PM |
sorry i dont have any info since a machine shop built the engine
i can try to ask them if they remember its been a while and they get engines in and out all day i know that they installed a + .10 bigger piston ring but used the same pistons i trust the shop since they built my 5sgte and 2jzgte so im not ignorant in engines and since your local why dont you check out the engine i just hate having long conversations that will lead to nothing so you had the block bored over 1MM? and you have 1MM oversized rights? did you put in 1MM oversized pistons. im trying to figure out what was done. cause if you didnt, that engine needs to come apart. what is the ring gap set to? |
Dec 2, 2010 - 3:19 PM |
bellflower is not that local and there is absolutly NO reason to put an oversized ring in if the piston is the standard size. in fact thats really bad to do because then the ring gap will not be right. I would have to tear apart the engine just to make sure everything is in the right spec. i cant see taht just by looking at it
Dec 2, 2010 - 4:02 PM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Dec 2, 2010 - 5:47 PM |
sure come by my house this weekend and bring your tools
and you measure it but be sure to put it back the way it was lets cut to the chase i just dont get it why dont you just build your own engine since you know all this stuff? bellflower is not that local and there is absolutly NO reason to put an oversized ring in if the piston is the standard size. in fact thats really bad to do because then the ring gap will not be right. I would have to tear apart the engine just to make sure everything is in the right spec. i cant see taht just by looking at it |
Dec 8, 2010 - 8:53 PM |
i dont have an engine to build and you have a good deal going, i would like to trust just dropping it in but i cant take that chance. ill send you a PM soon, im still very interested
Dec 10, 2010 - 1:07 AM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
he's asking because by what you're saying that engine was built wrong and not worth anything more than spare parts. You do NOT overbore a motor then stick a stock bore piston back in it with larger rings. The larger rings aren't going to seal everything up, and the pistons are going to have severe slap and destroy the cylinders. Smaay is asking VERY important information. If you don't know the exact specs of what you're selling you should find out or you could very easily end up selling the motor to someone and then getting sued for selling junk.
Lo-Fi Version | Time is now: November 25th, 2024 - 10:17 AM |
