> Greddy exhaust, Problem with the o2 censor
post Jan 19, 2003 - 3:46 AM
Blackcelliman
Joined Nov 8, '02
From Narragansett,RI
I just bought the Greddy cat back system and it has no place to plug in the o2 sensor that's located after the catty. Is there anyone out there that has a greddy system that has solved this problem or has had any prolonged problems because of it not being plugged in? I have gotton a boost in HP since it has been instaled but my car eats up a little more gas.
post Jan 20, 2003 - 12:57 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
the more you tune your car the more you will eat up gas... so dont worry about it. as for the sensor have a shop weld in a plug in for it
post Jan 20, 2003 - 1:17 AM
Mynzeyes
From Franklin/Nashville, TN
QUOTE (NEVERSTOP @ Jan 19 2003, 11:57 PM)
gas consumptions can also be corrected, however. w/ more tuning such as an aftermarket ignition and also some aftermarket fuel mods such as a regulator and S-AFC or something of that nature. that way you can set your fuel delivery down on a daily driving basis, but pumping it up when you feel the need. also, the S-AFC of an Air/Fuel gauge would give you the readings you need in order to not give the car too much fuel, or not enough. wink.gif
-John-
AIM==Mynzeyes
Lo-Fi Version Time is now: December 1st, 2024 - 1:59 AM
