> Air Bag Light Reset, Without taking a trip to the dealer
post Dec 1, 2010 - 6:36 PM
Imawakeyo
Joined Apr 20, '10
From Virginia
After removing my heater core and putting it back together, I connected the battery again to make sure all the electrical components worked. Only thing is I forgot to connect the airbag where the glovebox goes and the airbag light popped up permanently ;\ I tried the good ole' 30 minute battery disconnect but no success. Any way to reset it without having to pay the dealer $60 for something that'll take them 3 minutes? Any suggestions would be great, if not, dealer here i come!
post Dec 1, 2010 - 6:42 PM
mkernz22
Joined May 10, '10
From MA
did you plug the glove box one back in?
post Dec 1, 2010 - 6:43 PM
Imawakeyo
Joined Apr 20, '10
From Virginia
yeah, I backtracked and made sure everything was connected properly. The light kinda scared me at first lol
post Dec 1, 2010 - 7:17 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
Your going to need two heavy paper clips and jumper cables to reset your air bag warning light. The reset procedure is on the site somewhere. You reset it on your test module onder the hood.
Here's the reset procedure I used to reset mine.
To clear the SRS air bag error code do the following:
Connect the two wires (straightened out paper clips) to terminals Tc and Ab
Turn the ignition switch to on and wait at least six seconds
Starting with the tc terminal, apply body ground alternately to tc and ab twice each in cycles of about one second
Finally keep applying body ground to tc
after a few seconds the air bag light will start to blink and cancellation of the codes is complete.
This post has been edited by pyeatts: Dec 1, 2010 - 7:28 PM
post Dec 2, 2010 - 1:37 PM
Imawakeyo
Joined Apr 20, '10
From Virginia
edit: I understand now tongue.gif Gonna give this a go now. Cheers mate, much appreciated!
This post has been edited by Imawakeyo: Dec 2, 2010 - 1:44 PM
Lo-Fi Version Time is now: December 4th, 2024 - 9:46 AM
