post Dec 5, 2010 - 12:46 PM
Tech-Nics
Joined Jun 18, '08
___
This post has been edited by Tech-Nics: Dec 7, 2010 - 11:41 AM
post Dec 5, 2010 - 3:17 PM
clownpRon
Joined Oct 24, '10
From Chicago
Try checking the fuel filter.
post Dec 6, 2010 - 6:27 PM
Remy
Joined Jan 25, '06
From MN
Test coil and connectors on the distributor first then If you never replaced the fuel filter It would be a good time to change it and get the fuel psi tested too while your replacing your fuel filter could be your fuel pump is starting to take a dump on you too.
Jump t1 and te1 in the diag box to see if any codes are saved on the ecu just because your check engine light is not on doesn't mean your engine is not throwing codes.
"To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version Time is now: November 25th, 2024 - 11:30 PM
