![]() Enthusiast ![]() ![]() Joined Aug 28, '07 From france Currently Offline Reputation: 0 (0%) ![]() |
I saw some time ago one blog of a japanese guy that opened his tail ligths using boiling water. i tried without succes. Do you know if i can ue the oven to do this like some people taking out the lens of the projectors?
Any other solution? |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) ![]() |
oven does work. be careful and make sure that when you put it back together the seal is good.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) ![]() |
r u trying to get rid of the amber part if so id rather just cut it
new project groving up in my head,ill post about it later if done, i have some ideas, but not everything is defined yet
i have a spare set of tailights at home(not in so good shape now) so i dont mind testing on them before, but i want to be able to know how to take them apart safely. So oven should be okay? any temp recomendation? I was thinking of using windshield glue to seal them again |
my friend took his headlights apart in his 7th gen celica. i am guessing that it is a low temp setting.
slow cooked!
200* for about a minute then check it. If glue not pliable enough insert for another 30seconds. Re check. Still not? Work in small time increments till its just soft enough. You want as little time in oven as needed.to acconplish goal
![]() Enthusiast ![]() ![]() Joined Nov 21, '05 From England Currently Offline Reputation: 6 (100%) ![]() |
I've done it on a number of other units including MR2's and Supra MK3's. I find about 100 deg C in an electric fan oven works fine, but be sure that the unit doesn't touch the shelves or sides. About 10 mins should be about right.
![]() and here's what was inside.... ![]() before........ ![]() and after....... ![]() The Gen 6's will be more difficult - more like the MR2. I found it helpful using half clothes pegs to act as levers reducing chance of damaging lens compared to using say screwdrivers. You will need to ease a bit a time, putting in the oven several times to warm it up again ![]() ![]() Hope that helps -------------------- Has your car ever been on T.V? Mine was used in the opening sequences here - note the clear turns and front LED's
http://videos.streetfire.net/video/Wheeler...11-9c0f00a0b820 |
ill try this around the 26, stay tuned
good luck
Lo-Fi Version | Time is now: February 19th, 2025 - 9:54 PM |
