Climate Control Blower, Making Strange Noise |
Dec 9, 2010 - 8:18 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
About 3 or 4 months ago i went with some friends up to a car show about 2 hours away from my house, after a stop my blower started to make a funny noise.
i looked on the floor and there was what looked like pink fiberglass insulation and the fan is making the most god awful humming noise when on high, does anyone know whats up with this thing or how i could fix it? -------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Dec 9, 2010 - 8:25 AM |
Enthusiast Joined Apr 20, '10 From Virginia Currently Offline Reputation: 0 (0%) |
It might just be that it clogged. Try taking it out and cleaning it putting it back on. Should get rid of the noise. There's all kind of stuff floating around in there and sometimes it doesn't go out the vents but into the blower. & it just keeps accumulating more and more in there.
Dec 9, 2010 - 9:19 AM |
So im guessing i get to take the dashboard off to do this?
Dec 9, 2010 - 4:49 PM |
Nope, if it's the blower motor like your saying it's 4 screws I think under the glove box. All that really needs to come off is the glove box.
Dec 11, 2010 - 1:41 AM |
Enthusiast Joined Dec 11, '10 From qc Currently Offline Reputation: 0 (0%) |
the heater core is leaking...
Show Previous Next Celica REMOVAL AND INSTALLATION 1. Disconnect the negative battery cable. 2. Drain the cooling system into a clean container for reuse. 3. Discharge and recover the air conditioning system refrigerant. 4. Remove the evaporator housing by performing the following procedure: * Disconnect the refrigerant lines from the evaporator core. Discard the O-rings. Plug the openings to prevent contamination. * Remove the 2 grommets and the drain pipe grommet. * At the passenger's side, remove the lower finish panel. * Disconnect the evaporator housing's electrical connector. * Remove the evaporator housing-to-chassis 3 nuts and 4 bolts. * Remove the evaporator housing. 5. Remove the heater valve-to-cowl bolt. 6. Remove the heater hoses from the heater core pipes. 7. Remove the heater pipe grommets. 8. Remove the air bag module and the steering wheel by performing the following procedure: * Place the front wheels in the straight-ahead position. * At both sides of the steering wheel, remove the screw covers. * Using a Torx socket, loosen the 2 air bag module-to-steering wheel Torx screws until the circumference ring catches on the screw case. * Carefully, remove the air bag module and disconnect the electrical connector. * Remove the steering wheel nut. * Using a steering wheel puller, press the steering wheel from the steering column. 9. Remove the instrument panel and reinforcement by performing the following procedure: * Remove the front pillar lower garnishes and the pillar garnishes. * Remove the front door scuff plates. * Remove the cowl side trim boards. * Remove the steering column covers. * Pry out the upper console panel by disengaging the 4 clips. * Remove the console box. * Remove the No. 1 finish panel. * Remove the finish panel and the combination switch. * Remove the lower cluster finish panel and the cluster finish panel. * Remove the No. 1 register and the combination meter. * Remove the 2 center cluster finish panel screws; then, pry out the finish panel. * Remove the air conditioning control assembly. * Remove the lower finish panel. * Remove the glove compartment door finish plate located inside the lower finish panel. * Pull up the air bag electrical connector and disconnect it. * Remove the 5 lower finish panel screws and the panel. * Remove the 4 bolts and lower pad inserts. * Remove the 4 lower center finish panel screws and the panel. * Remove the No. 2 side defroster nozzle. * Disconnect the instrument panel electrical connectors. * Remove the instrument panel 9 bolts and 2 nuts. * Remove the instrument panel. * Remove the No. 1 center console bracket bolt and 2 nuts. * Remove the No. 2 center console bracket nut and bolt. * Remove the brake spring. * Remove the center console bracket support 6 bolts and 2 nuts. * Remove the center console bracket. 10. Disconnect the connector and the electrical connector from the heater housing. 11. Remove the 4 heater housing-to-chassis nuts and heater housing. 12. Remove the 2 air outlet damper control servo motor screws and the servo motor. 13. Remove the air vent duct. 14. Remove the 2 heater air duct screws, the 2 clips and the duct. 15. Remove the 3 heater pipe clamp screws and the clamps. 16. Remove the heater core from the heater housing. Exploded view of the air bag module, steering wheel and related components (typical) — Celica Exploded view of the instrument panel and related components — Celica Exploded view of the ventilation system, wiring harness and related components — Celica Exploded view of the heater core, heater housing, evaporator housing and related components — Celica To install: 17. Install the heater core to the heater housing. 18. Install the heater pipe clamp and the 3 clamp screws. 19. Install the heater air duct, the 2 clips and the 2 duct screws. 20. Install the air vent duct. 21. Install the air outlet damper control servo motor and the 2 servo motor screws. 22. Install the heater housing and 4 heater housing-to-chassis nuts. 23. Connect the connector and the electrical connector to the heater housing. 24. Install the air bag module and the steering wheel by performing the following procedure: * Align the matchmarks and install the steering wheel to the steering column. * Install the steering wheel nut and torque the nut to 26 ft. lbs. (35 Nm). * Carefully, connect the electrical connector and install the air bag module. * Using a Torx socket, tighten the 2 air bag module-to-steering wheel Torx screws to 78 inch lbs. (8.8 Nm). * At both sides of the steering wheel, install the screw covers. 25. Install the instrument panel and reinforcement by performing the following procedure: * Install the center console bracket. * Install the center console bracket support 6 bolts and 2 nuts. * Install the brake spring. * Install the No. 2 center console bracket nut and bolt. * Install the No. 1 center console bracket bolt and 2 nuts. * Install the instrument panel. * Install the instrument panel 9 bolts and 2 nuts. * Connect the instrument panel electrical connectors. * Install the No. 2 side defroster nozzle. * Install the lower center finish panel and the 4 panel screws. * Install the 4 bolts and lower pad inserts. * Install the lower finish panel and the 5 panel screws. * Connect the air bag electrical connector. * Install the glove compartment door finish plate located inside the lower finish panel. * Install the lower finish panel. * Install the air conditioning control assembly. * Install the center cluster finish panel and the 2 finish panel screws. * Install the No. 1 register and the combination meter. * Install the lower cluster finish panel and the cluster finish panel. * Install the finish panel and the combination switch. * Install the No. 1 finish panel. * Install the console box. * Pry out the upper console panel by engaging the 4 clips. * Install the steering column covers. * Install the cowl side trim boards. * Install the front door scuff plates. * Install the front pillar lower garnishes and the pillar garnishes. 26. Install the heater pipe grommets. 27. Install the heater hoses to the heater core pipes. 28. Install the heater valve-to-cowl bolt. 29. Install the evaporator housing by performing the following procedure: * Install the evaporator housing. * Install the evaporator housing-to-chassis 3 nuts and 4 bolts. * Connect the evaporator housing's electrical connector. * At the passenger's side, install the lower finish panel. * Install the 2 grommets and the drain pipe grommet. * Using new O-rings, connect the refrigerant lines to the evaporator core. 30. Refill the cooling system. 31. Connect the negative battery cable. 32. Evacuate, charge and leak test the air conditioning system. 33. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks. About 3 or 4 months ago i went with some friends up to a car show about 2 hours away from my house, after a stop my blower started to make a funny noise. i looked on the floor and there was what looked like pink fiberglass insulation and the fan is making the most god awful humming noise when on high, does anyone know whats up with this thing or how i could fix it? |
Dec 12, 2010 - 10:15 AM |
Ohhhhh is that what it was lol? I didnt put two and two together because I replaced my heater core bout 2 weeks ago and I have to say its a PITA. Except I had a small puddle forming underneath the glove box which told me it was the heater core . Good look with that bro, if you need pictures or a video I've got some on removing the heater core. Worst 2 days of my life
Dec 14, 2010 - 12:03 AM |
Yeah i dont have any finals tomorrow so i may be doing this then
Dec 14, 2010 - 1:15 AM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
PLEASE post a video of a how to...i do need to clean mine because it blows dust and it smells...thanks a million!!
Lo-Fi Version | Time is now: January 10th, 2025 - 5:23 PM |
