blue led interior lighting, map light? |
Dec 12, 2010 - 10:37 AM |
Enthusiast Joined Feb 2, '10 From nowra, nsw, australia Currently Offline Reputation: 0 (0%) |
hey guys according to this thread from the interior lighting sticky(http://www.6gc.net/forums/index.php?showtopic=28472).....
it says the maplight bulb size is 293. just to double check, is the map light the light that is positioned on the roof above the front/centre of the car. if not does any1 know the bulb sizes for them lights because i want to change them to blue. thanks |
Dec 12, 2010 - 3:52 PM |
Enthusiast Joined Aug 12, '09 From Orange Beach, Alabama Currently Offline Reputation: 6 (100%) |
This is the site I use to find all of my lighting info, since its a US site the exterior light numbers might be different (I know the JDM tali lights are different but I am unsure about the Australian lights) but I am pretty sure the interior lights will be the same....
Sylvania -------------------- Failing to prepare is preparing to fail!
Dec 14, 2010 - 8:29 AM |
but is the light i want to replace the bulbs in the map light? (the light in the front centre roof)
Dec 14, 2010 - 9:24 AM |
I completely took out the bulb in mine. I bent / cut the metal that holds it in, out. I spliced the wiring so the metal has no power going to it. Then, I bought a LED board that had blue LEDs on it, and stuck it in there. Wired it in it and it's 10x brighter than a bulb would be! It lights the whole front half of my car up
Dec 14, 2010 - 7:37 PM |
I completely took out the bulb in mine. I bent / cut the metal that holds it in, out. I spliced the wiring so the metal has no power going to it. Then, I bought a LED board that had blue LEDs on it, and stuck it in there. Wired it in it and it's 10x brighter than a bulb would be! It lights the whole front half of my car up that sounds sick, and where did you get this led board, this sounds tempting |
Dec 14, 2010 - 7:59 PM |
I completely took out the bulb in mine. I bent / cut the metal that holds it in, out. I spliced the wiring so the metal has no power going to it. Then, I bought a LED board that had blue LEDs on it, and stuck it in there. Wired it in it and it's 10x brighter than a bulb would be! It lights the whole front half of my car up that sounds sick, and where did you get this led board, this sounds tempting Well I'm not sure if you have them over in Australia, but I bought mine in the US at Autozone for about $15 to $20 US. You might be able to find them online though! |
Dec 14, 2010 - 8:17 PM |
Enthusiast Joined Dec 14, '10 From Lansing MI Currently Offline Reputation: 1 (100%) |
I completely took out the bulb in mine. I bent / cut the metal that holds it in, out. I spliced the wiring so the metal has no power going to it. Then, I bought a LED board that had blue LEDs on it, and stuck it in there. Wired it in it and it's 10x brighter than a bulb would be! It lights the whole front half of my car up that sounds sick, and where did you get this led board, this sounds tempting Well I'm not sure if you have them over in Australia, but I bought mine in the US at Autozone for about $15 to $20 US. You might be able to find them online though! I'm doing the same with mine but with red LEDs do you have any pics |
Dec 14, 2010 - 8:19 PM |
I don't but I can easily get some in a few days!
Dec 14, 2010 - 8:28 PM |
Dec 27, 2010 - 11:22 AM |
Enthusiast Joined Oct 21, '05 From Okinawa, Japan Currently Offline Reputation: 0 (0%) |
I am not sure if you can find them online(I bet you could) but there are kits that they sell here in Japan that you can get that use an adapter that can plug into 4-6 different types of light sockets and then connects to an LED board so you don't have to hard-wire anything. (Safer and more reliable that way). I will try to find my packages and post pics for you but if you check this link out, there are pics of my map lights that I used. they are blue and a board of 9 LEDs. They are bright (as in light up the entire cabin and almost hurt your eyes but you don't lose your night vision) but the pics don't really do them justice.
Bam! -------------------- -Dan
1998 SSII Beams, work in progress... |
Jan 11, 2011 - 9:58 AM |
so what exactly do i need to buy to get the light in the centre of my roof blue?
if you could link me to the correct bulb on ebay or something that would be very appreciated. |
Jan 11, 2011 - 10:00 AM |
i never got pics, my bad lol
i'll get some tonight for you |
Jan 11, 2011 - 10:24 AM |
sick. do they have these led boards on ebay? i wouldnt have a clue which one would work and wouldnt etc.
this maybe? http://cgi.ebay.com/ebaymotors/12-SMD-LED-...sQ5fAccessories |
Jan 11, 2011 - 2:47 PM |
sick. do they have these led boards on ebay? i wouldnt have a clue which one would work and wouldnt etc. this maybe? http://cgi.ebay.com/ebaymotors/12-SMD-LED-...sQ5fAccessories those actually work very well i have two in my dome lights |
Jan 11, 2011 - 2:52 PM |
sick. do they have these led boards on ebay? i wouldnt have a clue which one would work and wouldnt etc. this maybe? http://cgi.ebay.com/ebaymotors/12-SMD-LED-...sQ5fAccessories those actually work very well i have two in my dome lights well im going to buy some then. how does the install of them work? |
Jan 11, 2011 - 11:55 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
you splice them in.
Jan 12, 2011 - 12:30 AM |
Jan 14, 2011 - 12:19 PM |
so which light globes do i need to update the ones that shine down onto our rear plates? i want really bright white ones!
Jan 16, 2011 - 12:53 PM |
bump. whatthe has a pic with ones i would want. thanks
Jan 16, 2011 - 5:02 PM |
Lo-Fi Version | Time is now: November 29th, 2024 - 6:17 PM |
