Enthusiast Joined Dec 14, '10 From slovakia Currently Offline Reputation: 0 (0%) ![]() |
440cc (2gen 3sgte) and 540cc (3gen 3sgte) injectors have same sizes?
540cc fits to 440 fuel rail?(same diameter part of which goes to fuel rail?-so are interchangeable? or where I can find dimensions these two injectors (picture with dimensions) I know that 440cc have spec this: 440cc @ 3 BAR 2.9 OHMS but how spec are 540cc? many thanks for reply |
440cc (2gen 3sgte) and 540cc (3gen 3sgte) injectors have same sizes? 540cc fits to 440 fuel rail?(same diameter part of which goes to fuel rail?-so are interchangeable? or where I can find dimensions these two injectors (picture with dimensions) I know that 440cc have spec this: 440cc @ 3 BAR 2.9 OHMS but how spec are 540cc? many thanks for reply they are interchangeable, the only diffrence being 540CC VS 440CC. -------------------- Former Team 5SFTE pro member ;)
and spec 540cc injectors are same as 440cc injectors?
i thing 540cc @ 3BAR 2.9OHMS? (correct me if I'm wrong) |
yup.
and now I use 295cc -high impedence 13.3ohms and when I use 540cc low 2.9ohms i must use 4 resistors? but what power of resistors?
engine is 4age 20v black top |
Enthusiast ![]() ![]() Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) ![]() |
get the OEM resistor pack and just wire it in
OEM resistor pack??? from what engine?
sorry but I dont understand..... some picture with resistor pack?? |
For the corrosponding engine your using
if you use 440cc gen 2 then use the 3sgte gen 2 injectors resistor pack if you use the 540 gen 3 injectors then use the 3sgte gen 3 resistor pack. You can also wire in some resistors inline with the wiring for the injecotrs |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
just get low impedance injectors, done!
ok..many thanks.
i understand.. but where to install resistor pack or 4x resistor?between what?injector and what cable(where go this cable?) because i have 4age 20v engine annd this engine not have resistor pack in stock-high impedence injectors... This post has been edited by jaroo021: Dec 17, 2010 - 11:41 AM |
Lo-Fi Version | Time is now: February 20th, 2025 - 2:55 AM |
