35 Pages V  « < 8 9 10 11 12 > »
> 1MZ-FE into my MR2, Building a 3SGTE these days.
post Mar 12, 2011 - 11:50 PM
mak5603
Joined Oct 20, '08
When I put my Kirks inserts in, my mounts weren't in the best shape, and they work great with the inserts. However mine weren't THAT bad.
2014 Toyota Rav4 XLE
post Mar 13, 2011 - 6:45 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
All of the mr2 guys says its real common, and since i'm putting in kirkosaurus inserts that I should be okay.
And the v6 guys say don't use the spacer unless you're reusing the bolts from the flex plate, which I'm not.
Back at it in 4 hours. Hope everyone remembered to set their clocks forward an hour!
**** Photobucket
post Mar 13, 2011 - 7:35 AM
Same thing happen when we did my cousin's mr2 swap.
We just stuck it back in with the mount inserts.
It's been fine so far.
post Mar 13, 2011 - 6:51 PM
95CelicaST
Joined Feb 5, '05
Today has been a bit frustrating.. but it's alright - this is a learning process.
Woke up early and got the flywheel and clutch kit torqued down, replaced the throw out bearing, and started mating the transmission up to the motor, where I ran into problem 1.
Problem 1: The little guide posts that come out of the bell housing of the transmission - one of them was running straight into another guide post on the motor, so since they are just pressed in, I pulled one out with vice grips and continued on, but it halted my progress for a bit.
Problem 2: I knew going into this that the bolt holes on the transmission didn't match perfectly to the 1MZ... but I was only able to get the two big bolts on top of the transmission in. I then found another matching one towards the bottom of the transmission. The last (4th) bolt that lines up isn't actually a bolt hole at all - it's a spot for a guide post thing to into the engine. No problem - I'll tap it. This leads me to problem number 3.
Problem 3: I live about 15 minutes away from the nearest town. I don't have the luxury of just heading into town for this or that. So I went into town to get a tap for the bolt hole. It was confirmed by V6 guru Jim King on MR2OC that the hole needs to be drilled and tapped for 12x1.25, which is what the main transmission bolts are. I went to town to get one, walked into the hardware store, grabbed the tap, paid and walked out. I got all the way home and started tapping the hole when I realized it wasn't working. I glanced at the package and realized I bought a 10x1.25, not a 12x1.25... And at that point I said screw it - I'm done for the day. I'm not driving all the way back to town for that. Not today.
So I'm stopped until I get home from work tomorrow. I'll go snap some pictures for you guys right now, but I can assure you they're a bit disappointing in terms of progress. I'm personally really peeved on how little I got done this weekend. kindasad.gif
On the other hand it's alright, because my new kirkosaurus mounts aren't here yet, nor are my shift cable bushings from CRW, and my DGR coilovers. They'll all be here tomorrow, so I would have needed to revisit a few things if I were to have installed it already.
**** Photobucket
post Mar 13, 2011 - 7:34 PM
Good attitude, at least. Best of luck.
This post has been edited by SwissFerdi: Mar 13, 2011 - 7:34 PM
post Mar 13, 2011 - 7:42 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
The little things...gotta love 'em.
Best of luck tapping that hole and getting the swap completed; patience is a virtue and haste makes waste so I guess this is just another moment to allow you to better your build.
Has no more Celicas
post Mar 13, 2011 - 7:54 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Eh, just buy a whole set of taps.
post Mar 13, 2011 - 7:57 PM
LOL. First time in the history of the internet where it actually could help somebody tap something.
post Mar 13, 2011 - 8:17 PM
95CelicaST
Joined Feb 5, '05
Better than beating that joint.....
Mwahahaha
**** Photobucket
post Mar 13, 2011 - 8:45 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (95CelicaST @ Mar 13, 2011 - 9:17 PM) *
Mwahahaha
That's the spirit!
Has no more Celicas
post Mar 14, 2011 - 6:39 PM
95CelicaST
Joined Feb 5, '05
Went on and checked the shipping status on my inserts... and they were accidentally shipped across the state... in the wrong direction. No inserts today. No motor install today. Lamesauce.
Should have coilovers by end of day... Still need to get pictures uploaded.... hold please.
**** Photobucket
post Mar 14, 2011 - 6:48 PM
95CelicaST
Joined Feb 5, '05
Getting ready. I need to pull my pants up... or get a smaller belt.
Nom nom nom nom
Removing the flex plate. Thank god for impact tools!
**** Photobucket
post Mar 14, 2011 - 9:06 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
random fact. batteries don't last as long when you leave them on concrete floors. just fyi. found out through experience.
-saw yours in the background
post Mar 14, 2011 - 9:16 PM
95CelicaST
Joined Feb 5, '05
That's my bangin' diehard cooler - not a real battery.
**** Photobucket
post Mar 14, 2011 - 9:19 PM
Bitter
Joined Mar 11, '06
Dumb question, you have a garage and its raining...yet you're working in the driveway under a tent.
post Mar 14, 2011 - 10:06 PM
95CelicaST
Joined Feb 5, '05
The hoist would hit the rafters.
**** Photobucket
post Mar 15, 2011 - 7:52 AM
Bitter
Joined Mar 11, '06
Ah, who needs rafters anyways!?
post Mar 15, 2011 - 8:44 AM
WEAKSAUCE IS OUT !!!!!
big paperweight!!!
post Mar 16, 2011 - 12:04 AM
95CelicaST
Joined Feb 5, '05
**** Photobucket
post Mar 16, 2011 - 12:30 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (95CelicaST @ Mar 15, 2011 - 11:04 PM) *
June '12 COTM
'95 AT200
Lo-Fi Version Time is now: December 2nd, 2024 - 8:09 PM
