35 Pages V  « < 14 15 16 17 18 > »
> 1MZ-FE into my MR2, Building a 3SGTE these days.
post Apr 11, 2011 - 7:45 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If my girlfriend was expecting, the last thing I would be doing is spending money on my car. That excuse would go over like a fart in church.
Better idea: tell them my girlfriend will make them lumpia.
**** Photobucket
post Apr 11, 2011 - 7:50 PM
Loempia > what I said. Man I love me some Indonesian...
Glad you agree, I read it in a book titled "Never Be Lied To Again" and thought it was the biggest crock of sh!t available.
On another note, how is the placement and balance versus the old 5S, any weight distribution change?
This post has been edited by SwissFerdi: Apr 11, 2011 - 7:57 PM
post Apr 12, 2011 - 4:06 PM
95CelicaST
Joined Feb 5, '05
Doesn't seem like any weight distribution change. The passenger side has always sat lower than the driver's side. When I installed the coilovers in the rear the driver's side sat up significantly higher than the passenger side - I ended up needing to lower the driver's side rear and raise the driver's side front to get it to equal out side to side.
**** Photobucket
post Apr 12, 2011 - 7:00 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
get it corner weighted and adjusted.
post Apr 13, 2011 - 3:14 PM
Ted95
Joined Mar 8, '09
From Westport, MA
thing looks sickk broo, sounds beastlyy, good work!
st205 powered ss3 coupe
post Apr 14, 2011 - 10:54 PM
jackassofalltrad...
Joined Apr 14, '11
From Ohio
Visit My Website
I was curious to know if you were able to figure out what this is.
Im also swapping a 1mzfe into my NA MR2. 91 red, just like yours. and I got a WRX, Im a systems admin as well.
Weird. Anyways check it out. Im concerned. Its from a 2000 ES 300. VVT-i with 2001 NON VVT-i heads..
Tell me your thoughts.
post Apr 15, 2011 - 4:58 AM
somebody is pulling your leg..
post Apr 15, 2011 - 4:34 PM
95CelicaST
Joined Feb 5, '05
Like others on the MR2 boards - It looks like an oil passageway.
Shop wasn't able to get to it this week. No problem. It just allows for more goodies to be here in time for the unveiling.
**** Photobucket
post Apr 18, 2011 - 5:35 PM
95CelicaST
Joined Feb 5, '05
They're just getting started on it after one guy being gone all last week. I went in and showed them what I need.
They're going to cut the front mount apart, and bolt the plate to the wall, then bolt the mount to the engine, and tack the mount together. Easy peasy. The bulk of my concerns just went right out the window smile.gif
I had a picture of the B-pipe that Brad Bedell had made for his V6 MR2 (the guy who made my headers) and I sent that to the mechanic so he knows how to do up the exhaust.
He also noticed that the EGR cooler plate on the backside of the motor was leaking a little coolant, so he's going to take care of it.
Should have it back at the end of this week! OM NOM
**** Photobucket
post Apr 22, 2011 - 11:05 PM
95CelicaST
Joined Feb 5, '05
Picked the car up this afternoon. Decided a good shakedown run would be to drive it from Enumclaw to Seattle (~30 miles) and back.
Findings on this shakedown run:
- I need to raise the front end a bit and turn up the stiffness on the coilovers, as it is presently set to the softest setting.
- I can smell gas, but I don't have a gas leak. Need to investigate. Probably an improperly ran vacuum line.
Other than that it was solid. It pulls well in all gears at any point in the RPM range. The exhaust isn't too loud unless I really get on it, and it has a hint of rasp due to the headers and lack of a catalytic converter.
OMG. Torque! Mwahahaha. I will get some videos up tomorrow.
**** Photobucket
post Apr 23, 2011 - 12:24 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
FCUK YEAH!!!!
June '12 COTM
'95 AT200
post Apr 23, 2011 - 9:22 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (HectortheRican @ Apr 23, 2011 - 1:24 AM) *
FCUK YEAH!!!!
x2!
Can't wait to see the videos and congratulations on completion of an incredible project.
Has no more Celicas
post Apr 23, 2011 - 1:20 PM
95CelicaST
Joined Feb 5, '05
Found the source of the gas smell - bad o-rings on the front bank injectors. Replacing the o-rings in about 30 minutes.
Pics and video will wait until tonight. My camera is in the lady's tC.
**** Photobucket
post Apr 23, 2011 - 3:57 PM
Bitter
Joined Mar 11, '06
post Apr 23, 2011 - 6:36 PM
95CelicaST
Joined Feb 5, '05
Replaced the o-rings, and the leak got worse. frown.gif what was first a small leak was now a fountain!
I then realized I did not lube the o-rings or grommets with oil beforehand, and I had pinched one and snapped it. Replaced them all over again and no more leak! biggrin.gif
Took it for a long drive and dialed in the suspension. All the way hard in the front, and 5 clicks back from hard in the rear. No more rubbing. I need an alignment still to straighten my steering wheel and to take the caster out of the passenger front. The tire is sticking out past the fender and rubs just a little on bumpy turns. Once I can put a couple degrees of camber I'll be golden.
The Mrs. gets off work at 6:30 (Pacific time) and we'll be getting some videos posted.
**** Photobucket
post Apr 23, 2011 - 9:31 PM
95CelicaST
Joined Feb 5, '05
Nevermind me slipping the clutch - I'm still trying to get used to the heavier clutch and lightweight flywheel.
http://www.youtube.com/watch?v=yzgwiux6g8U
This post has been edited by 95CelicaST: Apr 23, 2011 - 10:17 PM
**** Photobucket
post Apr 23, 2011 - 11:37 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Sounds good, pulls great, and very unique. Well done.
Compared to the old engine does it throw you back in your seat?
Has no more Celicas
post Apr 23, 2011 - 11:52 PM
95CelicaST
Joined Feb 5, '05
Oh yeah, definitely. It was weird being in 4th gear just cruising around and pressing the pedal to the floor used to cause the 5S to make a lot of noise without much acceleration. Now when I put my foot to the floor in 4th gear I get pushed back in my seat and it rockets forward.
To give you an idea - that clip is a 0 to ~ 70mph run. I let off right as I went around the corner out of sight... and that's with me slipping the clutch. Its quick. I recommend this swap to anyone!
**** Photobucket
post Apr 24, 2011 - 12:01 AM
Sounds quite good indeed, looks fast for sure. Walkaround video, moar video in general? I'm need moar.
Congratulations though.
post Apr 24, 2011 - 9:47 AM
95CelicaST
Joined Feb 5, '05
Moar will come this morning. I will do a walk around just for you. Haha.
**** Photobucket
Lo-Fi Version Time is now: November 27th, 2024 - 5:42 PM
