35 Pages V  « < 22 23 24 25 26 > »
> 1MZ-FE into my MR2, Building a 3SGTE these days.
post Dec 19, 2012 - 12:01 AM
oteck
Joined Oct 20, '12
From Canada
my setup is nearly code free thanks to my Neutral resistor box but i need to kill one last code the direct clutch speed is throwing at me above 3k. It doen't do anything but i'd like to kill it
It won't be the best setup until i get the 6spd in there hehe
Wait till i do a HCR build on my 2nd block, an yes your are seeing 2 3mz hybrids
This post has been edited by oteck: Dec 19, 2012 - 12:03 AM
post Dec 19, 2012 - 11:42 AM
My jaw hath dropped, sir.
post Jan 8, 2013 - 7:45 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (95CelicaST @ Jun 4, 2011 - 2:45 PM) *
The ACIS is working. The auto ECU thinks it's in park, so it isn't adjusting fuel trims. I think the Auto trans codes are causing the problems. The only real way to get rid of the codes is to go full standalone, which isn't really in my budget. My tuner quoted something like $2500 for a ViPEC system installed and tuned. He said that since I'm not really looking at building the car out any more than where it is now to just go with a SAFC or if I want to - Mega Squirt so that the fuel can be dialed back. I maxed out the wideband while doing the baseline, so who knows just how rich it is. Pulling back the fuel will at least net me a few more HP and better fuel economy.
Out at my house tethered to my iPhone right now, so the upload is going slow....
edit: Chart.
i have that same dip but not the one at 5500 RPMs whats that from? also you can get rid of all the codes by using a MT ECU...this is a pretty old post im sure you know all this now.
This post has been edited by Smaay: Jan 8, 2013 - 7:46 PM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 8, 2013 - 10:33 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
We weren't sure what exactly caused the dip, but we assumed it was either knock, or the ECU seeing a value (that we couldn't find ourselves) that we couldn't resolve. At the time of this dyno chart my only CEL was the AT speed sensor.
On the newer ECUs there is a pin that you can ground out that will put the ECU into a MT mode (I'm sure you're aware of that from MR2OC). I just said screw it and did it the proper way - with standalone EMS.
**** Photobucket
post Jan 9, 2013 - 11:15 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (95CelicaST @ Jan 8, 2013 - 11:33 PM) *
Did you or your tuner check for timing values around that RPM to see if they were linear or changed drastically? That kinda looks like a friend's old dyno chart where his timing would go from 30 degrees at around 2800 RPM to 8 degrees when the first PSI of boost hit.
This post has been edited by Syaoran: Jan 9, 2013 - 11:15 AM
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jan 9, 2013 - 1:12 PM
95CelicaST
Joined Feb 5, '05
Yeah I had my phone set synced to my OBD-II dongle and was monitoring timing, fuel trims (long term and short term) for both banks, etc. and then charted the values on an RPM X-axis to more or less overlay with my dyno. Timing and fuel was all within spec.
We assumed the auto ECU - despite what others say - really does seem to have issues with not seeing an auto trans.
**** Photobucket
post Jan 9, 2013 - 7:40 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah that dip is from the ACIS. thats where the throttle plate is moving
post Jan 9, 2013 - 8:40 PM
95CelicaST
Joined Feb 5, '05
How could that be ACIS when it is gone from my standalone dyno graph, but is still hooked up?
Or are you saying that ACIS was causing the ECU to screw up.
**** Photobucket
post Jan 10, 2013 - 10:25 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
probably because the stand alone is not sending the signal to the VSV to activate the ACIS. thats telling me that your runners are not optimum and out could gain more power.
you are really making me want another MKII. i sold mine for my Supra about 7 years ago.
post Jan 10, 2013 - 11:09 AM
95CelicaST
Joined Feb 5, '05
Why don't you fly up here and drive this one home.
**** Photobucket
post Jan 16, 2013 - 12:25 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
tempting, what are you considering?
post Jan 16, 2013 - 4:52 PM
95CelicaST
Joined Feb 5, '05
No idea. I know I won't get anywhere near what I have into it, and I can certainly remove expensive items to meet a price point (i.e. CF steering wheel, LinkECU, Sparco seats.. Those total over $4100 alone) but I would like to see 10K as it sits all professionally detailed and polished up, but I might entertain offers/trades +\- cash. Meh. I flip flop on this idea. If someone made me an offer I couldn't refuse I would let it go. Could always use some money to buy an AVO turbo kit for my FR-S.
If you're actually interested feel free to PM me.
**** Photobucket
post Jan 16, 2013 - 9:32 PM
Sad, always seems to happen. Build a car, sell within a year. You've a good replacement though.
post Jan 16, 2013 - 10:46 PM
95CelicaST
Joined Feb 5, '05
The problem is that it just sits all week, and I usually only get to take it out for a ~10 mile jaunt on the weekends. It is about 50 miles away from where I live, so I can't mix it up and drive it to work one day or something. As we get closer to the car show season I will be refreshing things on it, but its pretty much done, you know? I don't want to put a cage in it, or a body kit, or put any more money into the motor, as I have a TON into it already. I was actually contemplating selling off the Sparcos for a set of clean leather MR2 seats and possibly take the interior down the classy OEM feel. It deserves to be driven, and I am not doing that as much as I should.
As I said - if someone made me an offer I couldn't refuse I would let it go. Otherwise it will stay with me and I'll keep it as a weekend/show car... like it currently is.
**** Photobucket
post Jan 16, 2013 - 11:51 PM
Box
Joined Feb 23, '12
From Warrior, AL
If I had the money I'd have to buy it. Best of luck to you whichever route you want to go.
2001 Miata LS 5-speed
Box
Joined Feb 23, '12
From Warrior, AL
This post has been edited by Box: Jan 16, 2013 - 11:51 PM
post Jan 17, 2013 - 6:08 PM
QUOTE (95CelicaST @ Jan 16, 2013 - 10:46 PM) *
Understood, and agreed. Trade for me Celica, I'll drive it. My qualifications are sim practice in lift- and snap-oversteer.
This post has been edited by SwissFerdi: Jan 17, 2013 - 6:09 PM
post Jan 17, 2013 - 7:55 PM
block
Joined Jul 27, '06
From Soda
Car sits beautifully as-is. I had a MR2 Turbo and it was a great car. This car should've came with a V6 from factory smile.gif If my investments weren't going into a cabin, I'd definitely be interested in purchashing this vechicle. We'll see how things go and how long you'll have this car smile.gif GL on whatever you do to this beautiful car!
post Feb 14, 2013 - 8:41 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (95CelicaST @ Jan 16, 2013 - 9:46 PM) *
Build a shed and keep it at home?
post Feb 15, 2013 - 2:17 AM
95CelicaST
Joined Feb 5, '05
I put the stock seats back in it and have been using it as my commuter for the week. I dropped $1100 at a local upholstery shop on recovering the stock seats in Katzkin leather as well as the door cards. Scheduled for Tuesday next week for installation and pics will follow.
I also picked up a gauge cluster from a local MR2 owner to cannibalize the voltmeter from, as mine is broken (reads 18+ at all times).
First car show of the year kicks off on 3/9 here in Seattle so more pictures will follow.
**** Photobucket
Lo-Fi Version Time is now: November 23rd, 2024 - 2:15 PM
