> How would you know if your car is a Cali emissions car?
post Dec 16, 2010 - 2:48 PM
Tech-Nics
Joined Jun 18, '08
Just wanted to know cause my car has been at the shop and they were waiting for a ignition coil for it. When I called to see if my car was ready they told me to come tomorrow cause they got the wrong ignition coil cause apparently my car is from Cali and the ignition coils are different than a non cali emissions ignition coil. Is there a way to know if my car is a Cali emissions car for future reference.
post Dec 16, 2010 - 4:32 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Easiest way that I know is the dizzy. Fed spec have 4 wires (coil inside) and cali spec have 5 wires (external coil). On top of that it should say somewhere on one of the stickers under the hood.
post Dec 16, 2010 - 7:56 PM
Remy
Joined Jan 25, '06
From MN
Their should be a sticker on your hood that tells you if you have FED or CALI spec emission car if you have a cali spec the coil would be external located under the igniter if you have a fed spec it would be located inside the distributor.
"To Protect And To Serve The Wealthy" -POLICE
post Dec 16, 2010 - 8:24 PM
Tech-Nics
Joined Jun 18, '08
Great. Don't have that hood anymore cause I did the GT-4 conversion on it. I bought the car from NJ dealer and thought it was a FED car not Cali. Guess I should have gotten the "Carfax".
post Dec 16, 2010 - 8:49 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
dealer should be able to tell you by the VIN.
post Dec 16, 2010 - 9:00 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Spider77 @ Dec 16, 2010 - 4:32 PM) *
I don't believe that wire part is true because my auto has 5 wires and my manual only has 4..
post Dec 16, 2010 - 10:09 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
couldnt you just look to see if it had two o2 sensors..or am i wrong?
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Dec 17, 2010 - 7:58 AM
if you dont have a firewall mounted coil (pre 96) then you have a federal car.
all 96+ are cali spec.
post Dec 17, 2010 - 6:15 PM
chacha
Joined Dec 29, '05
From So-Cal
cali spec where the primary o2 sensor is, there should be another 02 sensor as a back up on the 94-95 for obd1, for obd2, there's those two in the front...pre-cat o2 sensor (your PRIMARY), post-cat o2 sensor (back-up) and finally another where the catalyic conv is.
post Dec 17, 2010 - 7:14 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (mkernz22 @ Dec 16, 2010 - 9:00 PM) *
No, I'm pretty sure that it is true. transmissions have nothing to do with the ignition system. Where as an external (5 wires) vs internal (4 wires) coil is plain as day. Maybe your auto is cali spec (which I didnt know that it was all 96+, but it makes sense) and your manual is a fed spec?
post Dec 17, 2010 - 7:22 PM
mkernz22
Joined May 10, '10
From MA
I'll take a look again tomorrow haha it's too late noww
Lo-Fi Version Time is now: January 10th, 2025 - 7:04 PM
