> Engine struggle at 5k & up???, Spark plugs?
post Dec 17, 2010 - 8:42 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
What's up guys?
I asked Culp about this already and he advised me that it is probably the spark plugs, wires, etc. But I thought I'd ask around, even though he is a veteran at Celica problems. I have a 94 GT with a swapped 3rd gen 3SGTE, FMIC, Greddy Boost Controller, HKS BOV, and 3 inch piping with a Apexi exhaust. Not sure if all this is relevant, just thought I'd let you guys know my setup in case any of these things has to do with the problem. I usually don't drive my car hard, but the other day I tried to red line it and when I reached about 5k, the engine started to struggle to get higher. When I punched it, it pulled HARD. But when I reached 5k it wasn't pulling so hard again. Any suggestions on what may be causing this? I didn't check to see if the boost was still hitting hard, but I doubt this is a turbo problem. Thanks in advanced for any help!
-Ryan
post Dec 17, 2010 - 8:52 AM
how much boost are you running?
prolly worn ignition components as stevenson suggested.
post Dec 18, 2010 - 9:54 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (presure2 @ Dec 17, 2010 - 8:52 AM) *
I'm currently running 10lbs. Axel04 told me that stock boost for a 3S is 13lbs, can anyone confirm this? I guess changing the ignition components is what I'll be doing this weekend then.
-Ryan
post Dec 18, 2010 - 10:31 AM
QUOTE (str8thugginit4ya @ Dec 18, 2010 - 9:54 AM) *
-Ryan
Yes 13 is stock. You can even safely set it to 15psi and drive around like that all day long without any problems.
post Dec 18, 2010 - 6:31 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (lagos @ Dec 18, 2010 - 11:31 AM) *
-Ryan
Thanks Lagos. This may be a dumb question but if you have the boost set lower, would it save on the gas mileage? I would think so, but just to know for sure.
-Ryan
post Dec 19, 2010 - 10:35 AM
depends on how you drive. If you floor it everywhere then yes because your car will be making less power and using less gas.
post Dec 19, 2010 - 10:43 AM
Culpable04
Joined Apr 17, '06
From New Jersey
as long as you drive responsably you will get good MPG out of this engine, I mean considering the power it has and such.
on a regular week I get pretty close to 30 MPG driving to work ( 90 miles round trip ) I'm currently running 17 psi, I can get as low as 18 MPG when enjoying the car on weekends. so it's all on your driving.
post Dec 19, 2010 - 2:12 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (Culpable04 @ Dec 19, 2010 - 11:43 AM) *
Sounds good! Thanks Culp. Yea, I don't really punch it too much. If I do, it's on the rarest of occasions. Thanks for all the info guys!
-Ryan
Lo-Fi Version Time is now: November 23rd, 2024 - 2:34 AM
