> map-sensor 3s-gte
post Dec 22, 2010 - 12:40 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Hello!
I got error code 31. map sensor i think. Car runs good at idling. but when i give little gas it's like running on 3.
Where to buy new map sensor?
post Dec 22, 2010 - 1:18 PM
check the vac line to it, it may be cracked and just need replacing.
post Dec 22, 2010 - 1:54 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Checked all lines. they are ok.
post Dec 29, 2010 - 2:49 PM
Gt4Driver
Joined Nov 2, '06
From Finland
well. i ordered new map sensor(turbo pressure sensor) from toyota dealer. 400€ i hope that is broken. because i did not find anything else.
vacuum lines checked and fuses. it runs great at idle. so i don't think it's a bad spark. I will tell you if the new sensor helps. and ask help if it doesn't smile.gif
post Dec 29, 2010 - 2:59 PM
QUOTE (Gt4Driver @ Dec 29, 2010 - 2:49 PM) *
ouch.
prolly should have seen if member gottagoturbo could get you one used, prolly less than half the price you paid.
post Jan 7, 2011 - 5:53 AM
Gt4Driver
Joined Nov 2, '06
From Finland
Ok. I put a new sensor in. and broblem solved. Car runs better than ever smile.gif
Lo-Fi Version Time is now: February 22nd, 2025 - 3:19 AM
