4 Pages V  < 1 2 3 4 >
> B.E.A.M.S., Got myself a christmas present
post Sep 3, 2011 - 7:39 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
you talking about this one?:
post Sep 3, 2011 - 8:24 PM
richee3
Joined Jun 29, '08
From Denver
The Avalon uses the same MAF so you should be good there. As sensitive as it is, I would try to stay with a Toyota MAF, but you've already driven the car so that shouldn't be your problem. What do you mean, "built the intake?" I assume you mean you put the pipe and air filter in since that was the first post with the pipe pictured. But you might have actually built one yourself so I'm just checking there. Does the car idle well? Rev in neutral?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 3, 2011 - 11:11 PM
Dangercart1
Joined Dec 8, '09
yes lol, by built i mean i simply put one tube into another and capped it with a filter, as for idling, sometimes it idles very well, but other time it stalls or shakes violently at idle
[quote name='BonzaiCelica' date='Sep 3, 2011 - 8:39 PM' post='931625']
yes, that one, and the big one inside the tube
This post has been edited by Dangercart1: Sep 4, 2011 - 9:48 PM
post Sep 4, 2011 - 3:53 AM
BonzaiCelica
Joined Apr 24, '08
I forgot the name to that blue vacuum sensor. It goes to the charcoal canister I believe. Its not much of an importance at all and will not mess up the ecu if you don't have the on your engine. Guys from the beams forums and on 6gc said that thing isn't very important.
post Sep 6, 2011 - 9:14 AM
Dangercart1
Joined Dec 8, '09
QUOTE (BonzaiCelica @ Sep 4, 2011 - 4:53 AM) *
I have it hooked up, but it wasn't set up to the charcoal canister so i did that last night, I also cleaned the air intake and the MAF sensor, the car is still driving weird, it works fine but if the RPMs get to high it bucks like crazy, I don't have a tach right now so I'm not sure what the RPMs are but it happens around 60 in fifth gear, 50 in fourth, 30 in third, and 15 in second, i'm not sure about 1st
post Sep 6, 2011 - 9:56 PM
richee3
Joined Jun 29, '08
From Denver
60 is around 3K, same as the 5S. I assumed that's what you meant by "built the intake" but I wanted to double check. The blue thing that Bonzai posted is the VSV. As he said, it goes to the charcoal canister and isn't important to us at all. Apparently it makes a difference with a handful of MR2 guys, but not all of them and definitely not us. Does it matter if you're at full throttle or not, or does it just start running weird at a certain RPM, no matter what? Try unplugging the VVT solenoid and going for a drive. The BEAMS guys always like to start with that. It really sounds to me like a MAF issue. Is your check engine light on?
1998 Celica GT-
BEAMS Swapped.
post Sep 7, 2011 - 2:27 AM
Dangercart1
Joined Dec 8, '09
QUOTE (richee3 @ Sep 6, 2011 - 9:56 PM) *
I can't hit full throttle, at 60 (in fifth gear) the engine just bucks vigorously my thoughts are focused on the 4 engine codes, i also need to reset the ecu again soon to see if i got rid of them but two of them are involving the intake 1 involves the O2 sensor, but again i have no exhaust (hopefully getting that done tomorrow), and the fourth is fuel pump related (i have yet to get a stronger fuel pump) so i'm thinking its the ecu that's throwing off the engine of the lack of fuel, there are a few things i'm going to try, like which way is the MAF supposed to be facing? open end facing toward or away from the filter? Any suggestions are definitely appreciated, thank you all
This post has been edited by Dangercart1: Sep 7, 2011 - 2:28 AM
post Sep 7, 2011 - 2:45 AM
BonzaiCelica
Joined Apr 24, '08
test your fuel pressure directly at the pump with a 12 v battery.
No need to upgrade your fuel pump, the one used on all Naturally Aspirated Celica's from 7afe, 5sfe, 3rd gen 3sge and 3sfe are all the same fuel pump. Just make sure then when you test your fuel pressure, it read 38-44 psi.
post Sep 7, 2011 - 6:10 AM
richee3
Joined Jun 29, '08
From Denver
Open end of the MAF goes towards the air filter. That could be your issue. Definitely reset the ECU when you change/fix anything.
1998 Celica GT-
BEAMS Swapped.
post Sep 8, 2011 - 2:02 PM
Dangercart1
Joined Dec 8, '09
QUOTE (richee3 @ Sep 7, 2011 - 7:10 AM) *
I wish that was my problem, but i've got it facing the right way
post Sep 9, 2011 - 8:42 PM
Dangercart1
Joined Dec 8, '09
so went to get the exhaust done and they said they couldn't fabricate a down pipe, so now I'm on the hunt, would the down pipe from the 1.8 work? I included a link to one of those ebay ones it looks the same, i inquired about measurements but got no response.
http://cgi.ebay.com/ebaymotors/TOYOTA-CORO...emZ230670304312
post Sep 9, 2011 - 9:31 PM
richee3
Joined Jun 29, '08
From Denver
It looks similar but I doubt it. The BEAMS uses 2.25" exhaust, and that is only a 2" outlet. It's possible though. There is a BEAMS b pipe on EBay right now- $195 shipped, has the O2 sensor.
This post has been edited by richee3: Sep 9, 2011 - 9:34 PM
1998 Celica GT-
BEAMS Swapped.
post Sep 14, 2011 - 4:14 PM
Dangercart1
Joined Dec 8, '09
QUOTE (richee3 @ Sep 9, 2011 - 9:31 PM) *
ordered the pipe today
post Sep 20, 2011 - 12:08 PM
Dangercart1
Joined Dec 8, '09
The exhaust is finally on and sounds good, unfortunately it's still not running right, and the only thing i can think is the damn maf, is it possible i got a bad sensor? maybe it's the wrong one, i know toyota makes a few different ones with the same size plug. does anybody know the part number?
post Sep 20, 2011 - 12:20 PM
richee3
Joined Jun 29, '08
From Denver
The MAF is 22204-20010. It's from late 90's Avalons and Camrys with the 1MZ.
http://www.mr2.com/forums/part-numbers/Toy...aster-list.html
This post has been edited by richee3: Mar 3, 2013 - 4:18 PM
1998 Celica GT-
BEAMS Swapped.
post Sep 20, 2011 - 1:10 PM
Dangercart1
Joined Dec 8, '09
QUOTE (richee3 @ Sep 20, 2011 - 12:20 PM) *
The MAF is 22204-20010. It's from late 90's Avalons and Camrys wit the 1MZ.
yep, that's the one i got, I'm going to try and get another, I'm thinking the one i got was bad.
post Sep 20, 2011 - 3:42 PM
richee3
Joined Jun 29, '08
From Denver
A few questions.
What intake are you using?
Did you reset your ECU to clear the O2 sensor code, and did it clear the code?
You can't hit WOT in any gear, or just 5th? And what do youeans it starts bucking?
It's basically running, correct?
I'm just trying to get a good idea of what your motor is doing.
1998 Celica GT-
BEAMS Swapped.
post Sep 20, 2011 - 5:49 PM
Dangercart1
Joined Dec 8, '09
The top of the intake is the stock rubber elbow, which than goes to a metal tube made for the 97 avalon so i can fit the sensor in it, and the filter came with the tube. Yes i reset the ECU and yes it cleared the o2 sensor. I'm not sure what rpm it is, but no matter what gear I'm in once i hit it the whole car shakes violently. It's like the engine is trying to jump out of the car, and stops accelerating all together. Thanks for the help so far I do appreciate it!
post Sep 20, 2011 - 6:26 PM
richee3
Joined Jun 29, '08
From Denver
The Avalon and Camry use the same 1MZ engine so the intake should work, theoretically. Can you get a measurement of the inner diameter? There's a slim chance but maybe the Avalon and Camry use different pipes. I'm glad resetting the ECU cleared your O2 sensor code, but I'm assuming the other codes stayed? I'm leaning towards a bad sensor as well, though I would think a bad MAF would be bad across the board. Does the motor rev freely in neutral or does it still jump? It sounds like it might be a mechanical issue if it's jumping that bad. I'm sure you know my BEAMS is acting up as well, and our issues sound similar, apart from the fact that yours sounds much more severe. The help really isn't a problem. Other BEAMS owners have been gracious enough to help me out and it's the least I can do to help you out too.
1998 Celica GT-
BEAMS Swapped.
post Sep 23, 2011 - 2:34 PM
Dangercart1
Joined Dec 8, '09
Sorry for the lack of updates, school and work have been rough this week, also i managed to develop an oil leak out of the valve cover gasket, so i'm stuck doing that this weekend, I'll get that measurement as soon as it stops raining.
Lo-Fi Version Time is now: November 26th, 2024 - 3:28 AM
