4 Pages V  « < 2 3 4
> B.E.A.M.S., Got myself a christmas present
post Oct 9, 2011 - 12:23 PM
richee3
Joined Jun 29, '08
From Denver
Any update?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 18, 2011 - 2:18 PM
Dangercart1
Joined Dec 8, '09
Finally got a chance to start working on the celica again, I did some tests on the MAF sensor the resistance was fine but i fond no voltage when air was passing through it, so I'm thinking a bad sensor. I measured the intake tube it was almost exactly 3 inches, I also removed the drivers side steering knuckle and dropped it off at a shop to finally get the wheel bearing fixed. Another thing I want to check is the spark plug gaps, anybody know what they should be?
post Oct 18, 2011 - 3:23 PM
richee3
Joined Jun 29, '08
From Denver
Your intake pipe is slightly large. You need a 71 mm pipe and 3 inches is about 76 mm. I've had 2 intake pipes with a difference of .8 mm and I can feel a definite low end power difference between the two. I would think it will still run though. Spark plug gap should be .44". I've never checked voltage on my MAF, so let me do that and find out what kind of reading I get.
1998 Celica GT-
BEAMS Swapped.
post Oct 18, 2011 - 3:30 PM
Dangercart1
Joined Dec 8, '09
there is no specific level, when you blow into the end of the sensor the voltage should jump from 0 to however hard you blow, mine didn't budge
post Feb 11, 2013 - 9:38 PM
Dangercart1
Joined Dec 8, '09
Been a long time so I figured I would leave an update, the bucking problem was related to the ECU, I managed to find the correct ECU and the engine has been doing great since. Money has been tight with trying to pay for school put I've managed to put some tires and a good portion of the much needed steering/suspension parts on it. Still need the following:
Struts/springs
Throttle thermostat
Lower engine mounts and rear bracket
To locate the power steering leak
and much more.
I'll attempt to get some pictures up tomorrow in the daylight.
post Feb 11, 2013 - 11:21 PM
good thing...
post Feb 12, 2013 - 12:04 AM
Fate
Joined Nov 30, '04
From Atlantic City
woohoooooooooo!
post Mar 23, 2014 - 6:30 PM
NICOGP
Joined Mar 21, '14
From Denmark
Mine is doing the exact same thing after swap.
What was your conclusion exact, course I'm about to buy a new MAF.??
4 Pages V  « < 2 3 4
Lo-Fi Version Time is now: February 18th, 2025 - 6:59 AM
