> How do I remove these clips?
post Dec 26, 2010 - 4:25 PM
screamingchicken
Joined Aug 7, '09
From Denville, NJ
So I'm almost ready to pull my engine and trans, all I need to do now is undo the mounts and it can come right out. Except for the shifter cables, they're held in by these C-clips that I can't get out. I don't know what I'm missing here, is there something holding them in or are they just rusted to the case? Neither one will move at all.
post Dec 27, 2010 - 5:37 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
u need like bent nose pliers or something with alot of grip surface and pull it up firmly.. u might need to spray at it some crc or wd40 or watever toolbox in a can u guys use over there..
looks like urs are rusted to sh*t! lol
This post has been edited by delusionz: Dec 27, 2010 - 5:39 AM
Mike W
269awhp / 273ft-lbs
post Dec 27, 2010 - 11:49 AM
looks like they are pretty rusted up.
spray em down with some pb blaster, let it sit a couple minutes, give em a couple taps with a hammer.
lock on a good pair of needle nose vice grips along the gripping surface, and walk it up and out by wiggling the vice grips up and down.
post Dec 27, 2010 - 3:40 PM
screamingchicken
Joined Aug 7, '09
From Denville, NJ
Well I just tried it, and they still won't move! The clips are soaking in PB Blaster now, I'll try it again in an hour or so and hopefully they'll come out.
post Dec 27, 2010 - 4:32 PM
screamingchicken
Joined Aug 7, '09
From Denville, NJ
So they're still stuck! I'm thinking, if I can't get them off tomorrow, I'll have to disconnect the cables from the shifter itself in order to pull the trans. How do I do that? I looked at it briefly but couldn't see an easy way to remove them.
post Dec 27, 2010 - 10:44 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
grab tab with vice grips, wiggle side to side and pull up. once up a little, slip flat blade screw driver between gap and clip and pop it up the rest of the way.
post Dec 28, 2010 - 6:12 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
The corrosion is going to make it difficult. Spray it down and give it some love with a hammer. That'll help the penetrating fluid get where it needs to go, then grab some pliers and wiggle it side to side, once they start moving spray them down again and keep going. They'll climb their way off. Then think about sanding the contact surfaces when you put it all back together.
You'll probably bust some knuckles. Welcome to cars.
**** Photobucket
post Dec 28, 2010 - 7:39 PM
screamingchicken
Joined Aug 7, '09
From Denville, NJ
I ended up just taking them off the shifter. Turned out to be easy that way. Now I just have to get the rear engine mount off, and it can all come out!
post Dec 31, 2010 - 3:20 AM
h4rfang
Joined Dec 11, '10
From qc
lol having the same issue with my car... finally u just need to tap it with a long flat screwdriver and a hammer from under the car
you must tap here:
This post has been edited by h4rfang: Dec 31, 2010 - 3:20 AM
Lo-Fi Version Time is now: November 28th, 2024 - 1:55 PM
