24 Pages V  « < 4 5 6 7 8 > »
> Needle's progression thread
post Apr 9, 2011 - 11:36 PM
Needles
Joined Nov 18, '10
From montreal
im waiting for help before toutching that, i will created plug for water pump intercooler and intercooler and fuel bybass,
This post has been edited by Needles: Apr 10, 2011 - 1:34 PM
post Apr 11, 2011 - 7:55 AM
mkernz22
Joined May 10, '10
From MA
you're going to ruin your car man. get the wiring done by a professional because there is a decent amount that you have to change on it.
btw, 3 day swap my a$$ haha
post Apr 11, 2011 - 4:08 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (mkernz22 @ Apr 11, 2011 - 7:55 AM) *
lol 3 day swap , hahaha right, i was a dumb ass
btw am 99% sure the wire are well done
This post has been edited by Needles: Apr 11, 2011 - 4:09 PM
post Apr 15, 2011 - 1:26 PM
Needles
Joined Nov 18, '10
From montreal
the problem was bad connection of positive to the starter (baddly connected on the starter) now my starting circuit working fine,
the problem is i think i missed some ground or something cause the ground wire on the engine to front body just fried totally burn when i put the ignition to on position, at the same time my light go low
now all working fine, but before i try start my car again, i wanna find where it goes wrong whit the ground...maybe i missed one to firewall
post Apr 15, 2011 - 7:25 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Your either missing a ground or the grounds are not good enough.
post Apr 22, 2011 - 12:01 AM
Needles
Joined Nov 18, '10
From montreal
smile.gif http://www.youtube.com/watch?v=lK2witvI_UY
wink.gif http://www.youtube.com/watch?v=8m8gJe-oUV0
1994 and 1995 celica commercial
This post has been edited by Needles: Apr 22, 2011 - 12:06 AM
post Apr 22, 2011 - 1:40 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I still don't understand where you got the idea to rip apart the loom and twist wires together and tape them up before bothering to read pinouts, before checking grounds, before securing connections
Especially a whole bunch of wires at a time.
Seriously man what were you thinking?
I told you those wires you made to the starter motor were fuct up and what to check and jump and circuit test etc but you several times insisted on playing with your headlights instead. Did you not realise those guides were written unassuming of someone diving into the deep end with an engine swap and totally butchering the new loom.
If you can afford to pay for these parts, can you atleast pay someone with half a brain to correct your mistakes?
Mike W
269awhp / 273ft-lbs
post Apr 22, 2011 - 6:34 AM
Needles
Joined Nov 18, '10
From montreal
QUOTE (delusionz @ Apr 22, 2011 - 1:40 AM) *
no
i just try to swap it myself so i can learn
no one else have touched my car but only my two hand and im proud of it,
now i have a nice ground setup whit 4 gauge all new wire
i did post a lot for the ppl can see what happen when u have gremlins, so they can understand better what they going thru
anyway
i didnt had lot of time lately to spend on the car and it was not at my home, i will get it back today
if u ask urself why i rip apart the loom is because i was bored to loom it back nicely each time i check something, i WILL LEAVE IT LIKE That untill i make it start !!
and i had looked at the diagram , looked and looked again.. when u only have to splice one wire inside , and make connection for the ea1 plug, its normal i have start by the easy way before i get thru the diagram...
and there is no way i will let someone touch my wiring at this point , i just have to go check all connection carrefully
This post has been edited by Needles: Apr 22, 2011 - 6:35 AM
post Apr 22, 2011 - 6:49 AM
Needles
Joined Nov 18, '10
From montreal
ho yeah i took off the wire to the starter motor u talked about, it was just for one try
i have the original hooked up and the connectivity is good
This post has been edited by Needles: Apr 22, 2011 - 6:50 AM
post Apr 22, 2011 - 7:00 AM
Needles
Joined Nov 18, '10
From montreal
changing rubber on st185 shaft
Uploaded with ImageShack.us
post Apr 22, 2011 - 8:30 AM
mkernz22
Joined May 10, '10
From MA
dude, you keeping post sh!t about needing help and why your car wont start, well its because your wiring is majorly f*cked! there are some things in a swap you cannot do by yourself, and one of those is the wiring. it doesnt matter how big your grounds are because if you're frying the ground wires, then there is something messed up with the wiring.
post Apr 27, 2011 - 10:19 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (mkernz22 @ Apr 22, 2011 - 8:30 AM) *
my mistake: the EA1 wasnt plug correctly mad.gif mad.gif mad.gif because i had to took off some gray plastic around the plug was blocking the connection...
now i need..
-new fuel filter
-created intake connection for all circulation hose,
-switch for water intercooler pump, (i want put timer later for it)
-new battery (already have it)
-finish change rubber on the axles shaft (the inner rubber is 85$ at toyota ) mad.gif
-downpip[e 3" i need modified to connect custom exhaust
-need new driver side beering
post May 6, 2011 - 2:13 PM
Needles
Joined Nov 18, '10
From montreal
i have send my front axle (mr2 inner st185 outter ) for a rebuilt because i had hard time to put it back together
i just receive it and i got one rubber replaced , and all ball beaRING replaced whit biggger ball, cause the mecanic guy say its loose and a little bit worn so it can came out the shaft while driving,
This post has been edited by Needles: May 6, 2011 - 2:14 PM
post May 7, 2011 - 6:34 PM
korban
Joined Feb 5, '09
From New Zealand
There's a bit of a knack to putting CV's back together. Took me an hour to do my first one, 5min for the second, it's like one of those wooden puzzles that you need to slide together in the right order.
How much bigger were the new balls? Wouldn't want it to get hot and bind, I've seen a ball push right through the housing, made a real mess.
post May 9, 2011 - 3:38 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (korban @ May 7, 2011 - 7:34 PM) *
i will ask for the size of the new ball bearing , i dont know how much bigger they are, but i was about to put my axle on and one of them pop out cause i push to hard on it cause it was jamm easely...anyway that gonna be fix , i will try to put this one back toghether \
big news, my car is cranking over !! just need to connect fuel pump and see what happen smile.gif biggrin.gif
This post has been edited by Needles: May 9, 2011 - 4:07 PM
post May 9, 2011 - 4:56 PM
Needles
Joined Nov 18, '10
From montreal
woooooOOOOOOOOOOOOOOOOO ITS STARTED !! RIGHT ON WHIT THE fuel pump bypass, sound GOOD!!!!!!! its the best day of my life , i rev it a little, biggrin.gif biggrin.gif thank to all 6gc for support my project
post May 11, 2011 - 12:35 PM
Needles
Joined Nov 18, '10
From montreal
i try fix error 54 , but i dont have front clip or inc plug,
i search all over the web for 2 day now and i cant find a way to avoid it but only to imitate the original circuit whit resistor and everithing
i cant brige the sensor for water level since i dont have the plug for the pump
someone have a way to do it or a link ?
st205 into 94 gts
This post has been edited by Needles: May 11, 2011 - 12:47 PM
post May 11, 2011 - 6:36 PM
delusionz
Joined Feb 11, '08
can u find the wires at all? just 2 wires go from the sensor, one goes to ecu, one finds its way to ground somewhere in the loom, i think it branches off the loom near the IAT wires
Mike W
269awhp / 273ft-lbs
post May 11, 2011 - 7:00 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (delusionz @ May 11, 2011 - 7:36 PM) *
yes this 2 wire on the sensor on the charge cooler , but if i bridge it, does my cpu will run ok ? because i dont have the connection for the IWP and i want to plug it direct whit a switch so i can leave it on if i have to close the car and it still hot
so, if i bridge the sensor on the charge cooler, does it gonna bring the code 54 cause i dont have the water pump plug ?
post May 12, 2011 - 5:21 AM
delusionz
Joined Feb 11, '08
the factory setup is the best, running the water pump full time prolongs heatsoak, aswell as wears the pump out faster. also if the pump fails your ecu wont know to take safety precautions to prevent detonation and overheating until it's too late.
trust me on this one, theres 100% cons and 0% pros in running the pump full time, if you think you're going to get cooling faster what you're actually doing is spreading engine heat through all of the water since its not being cooled when the cars stationary, so that when you start to take off it will take longer as it has to cool ALL of the water, not just what happens to be sitting above the engine at the time.
and if that doesn't deter you, then the quick answer to your question is No, the ecu will throw a code without the intercooler pump
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: November 27th, 2024 - 4:13 AM
