Needle's progression thread |
May 29, 2011 - 5:51 PM |
Enthusiast Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
had full of problem , but once again, not thnat bad
after running the engine a bit, i did try it one good shot, finnally leak of the water pump (pump of engine) started after 5 min, there is a lot of water drip come from the seal of water pump second, leak at the oil filter, where the plug for oil temp is, its a big leak im worried cauze ive had fix that and place seal and everithing nicely beforte bolt the oil filter, and the oil comming out is very dirty , even if i did clean the engine before whit new oil, now i will need to buy another mobil one for 50 $ ****ty, can'T drive it like that, ftemperature water goes to 90*, boost gauge work really good, i saw my boost gauge get to 0.5 bar easily, but i dint check it enough, and i forgot to check my oil temp , engine temp just under the middle line, front axle fix, works great !! \d shifter really bad, i cant put it in 2 , or really , really hard to put it in 2, 4 and reverse, even if i back up the shifter console, i need to trick it to get in those gear, 1 and 3 gear goeas in whit no problem, almost impossible to get the 2nd gear and reverrse, when i get on the autoroute, i put it in 3 gears and i just try it too see the power, there was one new charger and and one new camaro, im pretty sure i scrared them lol, ITS POWERFULL!!!! THE 3sgte is one engine design for racing ... and its really do the job !the original bov sound crazy when nothing is plumb back ! 3 free day left, how hard it is to fix the water leak? , change the seal water pump ? i didnt search for that already... here is some pics here you can see the what the big leak does This post has been edited by Needles: May 29, 2011 - 8:09 PM |
May 30, 2011 - 1:27 AM |
2,4,R selection pushes the cable, 1,3,5 pulls the cable.
get the correct shifter cables so that 2,4,R make it all the way in -------------------- Mike W
May 30, 2011 - 2:10 PM |
Jun 4, 2011 - 10:41 PM |
Jun 10, 2011 - 12:06 PM |
my car wont start this morning,
there was 2 big vaccum hose, i took them out and put mini filter there, basically, its change nothing but filtered air fisrt, it start right on like others time but get to 2000 rpm, something was wrong, i press the gas, its work and get back to 2000rpm, so i was thinking something about the vaccum get wrong, the problem is i didnt touch anything else, i put back the old line whitout the mini filter (useless) to copy the old setup, came back in car and its barely starting, like dont have vaccum or gas somewhere and engine stop, i try start it back again , one little bip and now its only cranking and does nothing else, same as it was the fp stop working completely, problem is the fp working great and i can heard it a lot, can someone help plz, i was about to take one ride today and do plenty of work at the garage, but the celica wont saw it that way today... 3sgte 3gen This post has been edited by Needles: Jun 10, 2011 - 12:06 PM |
Jun 10, 2011 - 4:47 PM |
Enthusiast Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
"a bucket full of french fries next door ready too paddy field" You got me all in stitches
Jun 10, 2011 - 7:00 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
"a bucket full of french fries next door ready too paddy field" You got me all in stitches I just now noticed this... the fudge?? -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jun 11, 2011 - 1:08 AM |
Jun 11, 2011 - 1:22 AM |
i can t get the lock in for the shifter cable on my mr2 lsd,
it wont go in, i tried all the way, but i cant manage have good tool in there, i will do some custom thiner lock for it tommow, or any suggestion ? |
Jun 12, 2011 - 1:47 PM |
just a video of inside my car running, its was rainny and i cant rev up fast
http://s1201.photobucket.com/albums/bb350/...nt=HDV_0012.mp4 |
Jun 12, 2011 - 6:23 PM |
Jun 13, 2011 - 6:29 AM |
Enthusiast Joined Jan 1, '11 From uk Currently Offline Reputation: 3 (100%) |
nice rear interior ,im glad u fix the problem ,keep up good work buddy
Jun 13, 2011 - 9:14 AM |
im gonna buy some redline mt 90 for my e153,
but i read that mix it whit mtl 50/50 to keep the shifting smooth for the winter, so im gonna try 2 liter of redline mt90 and 2 liter mtl and see... This post has been edited by Needles: Jun 13, 2011 - 10:55 AM |
Jun 13, 2011 - 1:13 PM |
i drove my car today for 1 hour and half,
temperature look good, on the highway at 78 on the city 90 to 100 but i get at my home and wait a bit and close the car, and let the gauge open, and THE WATER TEMP GOES UP TO 108 !! i need to start the car and it goes to 102, and i stop it and it goes back to 108, is that normal , why my car getting hot like this after i close it, and there was full pressure on the radiator hose, i cant press on it and that was a really smooth ride and btw, the shifting is the best i ever try in a car, its absolutely perfect passing to 4 to 5th gears is so short and easy lol This post has been edited by Needles: Jun 13, 2011 - 1:16 PM |
Jun 14, 2011 - 1:46 PM |
Jun 14, 2011 - 2:47 PM |
Jun 14, 2011 - 3:15 PM |
Enthusiast Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
I will give your car a few months to live. YOU DON'T BOOST WHEN LOW ON FUEL.
Jun 14, 2011 - 4:04 PM |
I will give your car a few months to live. YOU DON'T BOOST WHEN LOW ON FUEL. my fuel tank leak if i put more than 25 $ on it.. i need to send it to get it rebuilt thats is why im running whit 10-15 $ of fuel in it, i wont go low on fuel whaT is that idea ? i have another car for daily |
Jun 14, 2011 - 4:12 PM |
working on the lower rocker Uploaded with ImageShack.us yeaah and done until the new paint Uploaded with ImageShack.us This post has been edited by Needles: Jun 14, 2011 - 4:14 PM |
So instead of fixing your gas tank that wont hold over 6 gallons, you decided to 3sgte swap you car..Seems rational to me. If you run low on fuel, then attempt to boost, the engine will starve for gas.
This post has been edited by SupraKid: Jun 14, 2011 - 4:18 PM |
Lo-Fi Version | Time is now: November 30th, 2024 - 4:02 AM |
