24 Pages V  < 1 2 3 4 > »
> Needle's progression thread
post Jan 17, 2011 - 6:04 PM
mkernz22
Joined May 10, '10
From MA
do MOAR research!!!!!!!
you've been on here for 2 months, you need to research. i'm going to be researching over a period of 4 years (not needed though) but that's how long I'll be in college. and no, 3 days is not possibly for a one man crew, probably not even a 2 or 3 man crew unless they really know what they are doing. do not jump the gun because you will mess something up.
This post has been edited by mkernz22: Jan 17, 2011 - 6:04 PM
post Jan 17, 2011 - 8:22 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (Needles @ Jan 17, 2011 - 1:18 PM) *
if u look in the sticky forced induction threat u will not find how to swap ur engine... just one for the 2th gen 3sgte.... not the same thing, we should have a how to replace 5sfe whit 3sgte whit a transmission that for fwd , but its all custum, and all lead to some kind of problem, what is the best way ? get 3sgte front engine from gt4 whit ecu and put the lsd tranny from mr2 whit some spacer in the boots and get the engine mount st205 or gt4 for the transmiision ,extended the wire harness ,
and the 3sgte clutch ? what is a54 ? is it the 2.2l one ? supra kid, u mean i can keep all original component in the transmission if i use the 5sfe transmission ? i heard that one part dont fit, i need to know the exact part i need in my original 5sfe tranny to fit in bolt on to the 3sgtg3
Its 80% the EXACT same.
If you have researched at ALL you'd find that the 2nd and 3rd gens are physically the same to swap in, the only major difference with the 2nd gen swap is the wiring nightmare. I can see you seem to be getting POed and ill tell you if you blow up and attempt to tell off a member your gonna lose everyone's support and help, so id advise against that. Its nice to see you seem to have learned some grammar skills though.
This post has been edited by SupraKid: Jan 17, 2011 - 8:23 PM
post Jan 18, 2011 - 8:16 PM
Needles
Joined Nov 18, '10
From montreal
3sgte sooon
This post has been edited by Needles: Feb 2, 2011 - 10:00 PM
post Jan 18, 2011 - 8:25 PM
Needles
Joined Nov 18, '10
From montreal
i had change a supra 88 engine by my self 8 years ago took 6 month, so i learn... and i will do it in 3 day, whitout mistake and maybe i will do a threat how to put 3sgte the easy way on the gt, i will do thew wiring harnees begfore the swap, andd i already found all the wiring diagram from 5sfe to 3sgte 3th gen, i let you know how it gonna be
post Jan 18, 2011 - 8:35 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
You have now rendered the last sentence in my last post untrue :\. What engine did you put in the mk3?Because unless its a jz engine its plug and play and a MUCH easier swap than a 3sgte swap. Are you going to be swapping alone or will you have other people helping you out? If your doing it alone look at at LEAST 4 solid days of swapping(if you know exactly what your doing and have 0 gremlins, both of which will not be true.)
This post has been edited by SupraKid: Jan 18, 2011 - 8:36 PM
post Jan 18, 2011 - 8:41 PM
Needles
Joined Nov 18, '10
From montreal
i will let u all know of my progress, all help is very appreciated , thanks
post Jan 18, 2011 - 8:45 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Needles @ Jan 18, 2011 - 8:25 PM) *
just because you did 1 engine swap does not mean you learned anything. supras are different than celicas. different body, different wiring, different engine, pretty much different everything! you have no experience with this car. what if you mess the swap up? you're going to be car-less for more than 3 days. THERE IS NO EASY WAY TO SWAP A 3S INTO THE GT! do you not comprehend what we are telling you?
post Jan 18, 2011 - 9:02 PM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
dude, its awesome you have a thread to show your progress and you want to swap and do allt hat cool stuff to your 6gc but seriously. do research. alot of it. talk to members who have swapped but use real legit questions. and look at build threads on 3sgte's.
‹Superaison› i'm a computer inclined guy..
‹Superaison› or girl. idk what gender I am anymore.
‹SeverX13› *facepalm*
suprakid: o sh!t
suprakid: i wanna get an obama chia pet
SeverX13: hahahahaha
post Jan 19, 2011 - 9:28 AM
mkernz22
Joined May 10, '10
From MA
lmao^
but searchsearchsearchsearchsearch!
This post has been edited by mkernz22: Jan 19, 2011 - 9:29 AM
post Jan 19, 2011 - 3:51 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (mkernz22 @ Jan 19, 2011 - 10:28 AM) *
lmao^
thats ok, i have already found all the info i need
post Jan 19, 2011 - 4:12 PM
mkernz22
Joined May 10, '10
From MA
alright then, i guess ill take your word for it....
post Jan 19, 2011 - 5:48 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
QUOTE (Needles @ Jan 19, 2011 - 2:51 PM) *
lmao^
Let us know when you start. I want to count the days.
June '12 COTM
'95 AT200
post Jan 21, 2011 - 3:21 PM
Needles
Joined Nov 18, '10
From montreal
lots and lots of very usefull info there http://gtfour.supras.org.nz/Technical.htm all about all modificatrion wink.gif
post Jan 21, 2011 - 6:10 PM
SeverX13
Joined Dec 4, '07
QUOTE (Needles @ Jan 21, 2011 - 4:21 PM) *
lots and lots of very usefull information here too Ultimate Celica Resource wink.gif
This post has been edited by SeverX13: Jan 21, 2011 - 6:10 PM
suprakid: o sh!t
post Jan 21, 2011 - 6:53 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
I really wish there was a facepalm expression on here. Your not going to do it in 3 days with no gremlins ext, Just the wiring if you do it yourself will take a day.
Its cool that you love your car, made a progression thread, showed you mods which are neat and tasteful to say the least. But your not going to swap in 3 days. Heres basic math if your doing it alone
Day 1 - Pull old engine
Day 2 - do wiring, and maybe run new harness
Day 3 - Replace old worn out parts, broken parts, missing parts ext.
Day 4 - Put in engine, connect harness, exhaust, ext.
Day 5 - Try and start car and search for the gremlins that are going to be there.
Day 6 - get on here and ask whats wrong.
Thats just basic and thats if your spending your entire day doing it.
I know you said youve found everything you needed to know, but you havnt. you cant compare a supra swap to a celica swap. Goodluck and I'll be watching and counting the days.
post Jan 22, 2011 - 12:02 AM
HectortheRican
Joined Dec 26, '09
QUOTE (SeverX13 @ Jan 21, 2011 - 6:10 PM) *
LOL high five sir
June '12 COTM
'95 AT200
post Jan 22, 2011 - 12:22 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (HectortheRican @ Jan 22, 2011 - 12:02 AM) *
LOL high five sir
post Jan 22, 2011 - 9:01 AM
Needles
Joined Nov 18, '10
From montreal
i just find a 4th gen 3sgte , its only 1500$ , if someone know if the transmission of my 5s will fit like it fit the 3th gen 3sgte, ^? rolleyes.gif
its ST215 GT-T
This post has been edited by Needles: Jan 22, 2011 - 9:21 AM
post Jan 22, 2011 - 1:00 PM
mkernz22
Joined May 10, '10
From MA
You can find a 3rd gen 3sgte for the same price.
It's hard to find maintenance parts (well parts in general) for the 4th Gen or so I've heard.
This post has been edited by mkernz22: Jan 22, 2011 - 1:01 PM
post Jan 22, 2011 - 2:41 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Dont buy from them or tiger japanese... word of advice.
Lo-Fi Version Time is now: November 23rd, 2024 - 2:16 AM
