![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) ![]() |
Still looks good but think the black better
-------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) ![]() |
![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
Nice lookin so far
Is that the finished product -------------------- 95 gt coupe, v6 swap weekend toy
Well get them done lol i wanna see them in the car asap lol
![]() -------------------- 95 gt coupe, v6 swap weekend toy
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) ![]() |
Looks pretty sweet
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) ![]() |
I gotta give it to ya.... i wish the one picture wasn't blurry. Those really have a chance at looking good if you can get the lenses cut to perfect shape and the insides finished up.
Nice work so far! ![]() -------------------- ![]() |
headlight going on slowly,
the only thing i care about is thaT the lenses is flat...\ but its still look good, so im gonna do it flat. ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us ![]() Uploaded with ImageShack.us |
Nice
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) ![]() |
wow thats pretty good
![]() Enthusiast ![]() ![]() ![]() Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) ![]() |
i like the progress that you are doing on the head lights and i believe that i have to solution for your current perdicament. what you need to do is make a smooth mold of the INSIDE of the head light lenses.. essentialy making a negative to be placed on a vacuume table. then make a posative casting using softened plexi. that way you can have the "sides" to the lens that you are looking to get so that the lens can then be mounted the the head light housing like normal.
much like this guy did for the inside shroud for his head lights.. i would say that the only additional step to the whole process would be to use some extremely high lvl (6000+) sand paper and then a buffing wheel, w/ a compound that will not tarnish the plexi. Five Axes did a how-to on how to make and use a vacuum table, in one of the import mags.. (can remember if it was Project car, Import Tuner, Modified, or D-Sport.) i really think that you would have better results using this process. ![]() -------------------- |
i like the progress that you are doing on the head lights and i believe that i have to solution for your current perdicament. what you need to do is make a smooth mold of the INSIDE of the head light lenses.. essentialy making a negative to be placed on a vacuume table. then make a posative casting using softened plexi. that way you can have the "sides" to the lens that you are looking to get so that the lens can then be mounted the the head light housing like normal. much like thius guy did for the inside shroud for his head lights.. i would say that the only additional step to the whole process would be to use some extremely high lvl (6000+) sand paper and then a buffing wheel, w/ a compound that will not tarnish the plexi. Five Axes did a how-to on how to make and use a vacuum table, in one of the import mags.. (can remember if it was Project car, Import Tuner, Modified, or D-Sport.) i really think that you would have better results using this process. ![]() thanks for the info . i just find that video , http://www.youtube.com/watch?v=t2uGPe0aZgU i just need to find a vacuum table now lol, but talking about the result, the black rubber around the headlight will hide all that stuff around the lenses, so, that mean this can be done easely by custom process, i , before i saw your suggestion,i was about to make the circle around the headlight made of plexiglass itself (it bend easely when the plexi is thin, ) in 4 or 5 piece, to correct the curve around, and put putty to make a good finish around the headlight, since we dont see it , , its gonna be finish whit silicone to stick to the lenses, i know its sound crazy, but that a way to do it. but if i found a vacuum table.... ill be able to do a perfect job like in the video (created easely a new inside pattern) and cover, This post has been edited by Needles: Feb 5, 2012 - 1:35 PM |
no problem
![]() the mag article showed how to make a vacuume table.. and as far as i can tell the only part that may take a few tries is the placement of a few of the suction holes. that would give a perfect moulding. good luck!!! -------------------- |
Looks goid now what are you doin ti the high beams
how do they look at night?
Lo-Fi Version | Time is now: April 21st, 2025 - 11:11 PM |
