> Help Auto door locks?
post Jan 1, 2011 - 5:22 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Hello my 94 celica gt after 4 years of ownership has decided to start locking her own doors when parked even if I leave the key in the ignition!!! This is not good as you all know eventually I will get locked out in the middle of nowhere. Can anyone tell me what might be the problem? IF this was some sort of option that just started to work incorrectly?
THanks,
Brandon
post Jan 1, 2011 - 9:25 PM
mjjsk
Joined Oct 16, '10
From Selkirk Manitoba Canada
mine does the same thing did you change your battery or do you got an aftermarket alarm and locker? I have the same problem all the time.
post Jan 1, 2011 - 9:30 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
The car came with an aftermarket alarm system but nothing to control it. THe owner didn't install it either so he couldn't tell me anything about it. So I am at a loss as to if it controls door locks. I believe it is made by radioshack. Do you have an aftermarket alarm? That is my guess as for now. I pulled the door lock fuse as I don't want to get stranded somewhere.
Thanks
post Jan 2, 2011 - 9:01 PM
mjjsk
Joined Oct 16, '10
ya i got a compustar 2 way and the owner of the car I bought it from said it acted up as soon as I changed the battery thats when the locks lock on its own also its something to do with the keyless entry and the battery I believe try to see if you got the alarm installed on your car or if you put your key in the passenger side will the doors unlock both sides if you unlock the the door?
post Jan 4, 2011 - 2:14 AM
bdog_v
Joined Jan 17, '06
From Wisconsin
'the key will unlock both sides from both sides. If that helps any?
post Jan 4, 2011 - 7:05 PM
mjjsk
Joined Oct 16, '10
you have to pull your battery out for 12 hours make it 13 cause it resets the whole locking system.
Lo-Fi Version Time is now: November 23rd, 2024 - 1:36 PM
