Check Engine Light is on, code 26.. |
Nov 30, 2003 - 2:07 PM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Can anyone help me here? Someone suggested a new air to fuel sensor and a new 02 sensor, anyone ever had this? Got any price estimates, anything to help would be great. I know i'm eating gas like crazy too. It's a code 26 if anyone has had that.
Dec 1, 2003 - 3:42 AM |
Enthusiast Joined Aug 17, '03 From Bangkok, Thailand. Currently Offline Reputation: 0 (0%) |
If the Code is "21" then you'll need a new O2 sensor.
Code"26" is "Air-Fuel ratio Rich Malfunction". The Trouble Areas are: => Injector Circuit. => Injectors. => Fuel Line Pressure. => Cold Start Injector. => ECU. Hope this helps... : ) : ) |
Dec 1, 2003 - 9:18 AM |
Enthusiast Joined Jul 8, '03 From Dallas, TX Currently Offline Reputation: 0 (0%) |
how did u come up with code "26"
Dec 1, 2003 - 11:01 AM |
Used the how-to on the site using a paper clip and the check engine light flashes.
Dec 8, 2003 - 9:59 AM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
New o2 sensor at advance auto is only like 35$ or so! most likely it would be the first sensor giving you problems and not the second one! there is a sensor up by the throttle body ... maybe pull it out and clean the connections??? I had error 27 b4 and it was the second sensor but you really do not need that one cause that one only really tells you if the cat is working or something dumb like that???
It is worth a try to pull some plugs and clean terminals on sensors and even to get a new 02 sensor cause that will clean up you fuel mix a little if you have never replaced the stock on. Try some fuel injector cleaner too... you never know!!!!! Sikboy posted this b4 to help out : http://www.off-road.com/toyota/tech/codes/ let us know what happens hope this helps??? dg This post has been edited by DG_Performance: Dec 8, 2003 - 10:02 AM -------------------- |
Lo-Fi Version | Time is now: January 15th, 2025 - 9:11 AM |
