Enthusiast ![]() ![]() Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) ![]() |
I am currently getting every bit of body work done on my car and all I need to find is a driver's side headlight assembly. The body shop said they could get one for around $150, but I told them to let me try on here first. The plastic outer shell is busted loose, and the easiest way to fix is simply replace it. Anybody that has one for a reasonable price PM me. If the price is good, I'll probably order tonight.
EDIT: I forgot to say I need just the low beam. Shop decided to go ahead and buy new passenger side, just need driver side. This post has been edited by d3ath2009: Jan 5, 2011 - 4:51 PM |
do you need the glass with it?
i would like to have the full assembly with glass if possible just to make things go faster. if it doesnt have the glass, the shop probably wouldnt b able to switch it out so i would end up attempting it myself. that would not end well.... so once again, i would rather have the full assembly WITH the glass
![]() Enthusiast ![]() Joined Jan 11, '07 From carmel, new york Currently Offline Reputation: 7 (100%) ![]() |
All I have is high beams
ohh
![]() This post has been edited by mkernz22: Jan 5, 2011 - 3:44 PM |
Enthusiast ![]() Joined Dec 25, '09 From NC, Charlotte Currently Offline Reputation: 2 (100%) ![]() |
I am currently getting every bit of body work done on my car and all I need to find is a driver's side headlight assembly. The body shop said they could get one for around $150, but I told them to let me try on here first. The plastic outer shell is busted loose, and the easiest way to fix is simply replace it. Anybody that has one for a reasonable price PM me. If the price is good, I'll probably order tonight. EDIT: I forgot to say I need just the low beam. Body Shop also needs passenger side headlight. They told me if I can find it for cheaper also, then they could put the money elsewhere. Same deal as drivers side, full assembly would be nice. http://s873.photobucket.com/albums/ab297/sanders81s/ |
Lo-Fi Version | Time is now: February 17th, 2025 - 2:32 AM |
