51 Pages V  « < 5 6 7 8 9 > »
> Green Bullet ST205 Re-Born, MODIFICATIONS, AND UPDATES!
post Jul 20, 2011 - 6:31 PM
bsamps4
Joined May 16, '10
From Raleigh
Another small update...
GT4 front end conversion ready!
Peep this! Thanx to TwistedCeli94 for the hood!!!
Can't wait till it's GreenMachine Greeeeeen!!!
This post has been edited by bsamps4: Sep 20, 2011 - 2:01 PM
post Jul 28, 2011 - 6:50 PM
bsamps4
Joined May 16, '10
From Raleigh
Test fit! Lines up quite well. As for the rubber seal that goes between the bumper and hood....how are you guys modifying yours to make it not look ridiculous? Or is there anyone on here with the seal and metal slip cover that goes over the bumper lip that is willing to sell theirs?
post Sep 16, 2011 - 9:35 PM
bsamps4
Joined May 16, '10
From Raleigh
A lot of progress has been made! The hood and bumper are nearly paint worthy! I've also got a few items that are on the way. My car had to be sent back to the body shop from previous repairs made in March, but I'm finally getting back on track.
If anyone would like the CURRENT Toyota part numbers for the items I've ordered LMK. I will post them, and hopefully benefit another 6gc'er.
Items on order include: Complete Engine Overhaul Gasket Kit (I will source the part numbers to these items if needed), Timing Belt, Water Pump Assy, Oil Pump Assy, Wiseco Pistons 86.5mm, Eagle H-Beam Rods w/ ARP Rod Bolts, ARP Main Studs, ARP Head Studs, 2nd Gen Plug Wires, Distributor Cap, Distributor Rotor, Hydraulic Timing Belt Tensioner, and ACL Bearings.
Engine Block is currently at machine shop being hot tanked and new freeze plugs installed. Will provide pic's when I can.
post Sep 17, 2011 - 12:34 AM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (bsamps4 @ Sep 16, 2011 - 10:35 PM) *
good progress my dude! cant wait to see some pics
as for the GT4 hood, it doesnt line up to the stock bumper properly. the GT4 hood has different lines in and shape the the stock bumper, some caqrs can pull it off quite well with a good exterior setup wink.gif cant wait to see the progress!
st205 powered ss3 coupe
post Sep 17, 2011 - 10:29 AM
bsamps4
Joined May 16, '10
From Raleigh
Been looking around today at different Manual Boost Controllers. Any body on this site ever use the "Grimmspeed" brand? Seems like a decent unit, and has a reasonable price.
Thoughts?
post Sep 17, 2011 - 11:00 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
QUOTE (bsamps4 @ Mar 21, 2011 - 5:37 PM) *
What on earth are these?
this is part of the anti-lag system, like the pipes on the ex-maifold and the 3way valve between intercooler and BOV,
but just for homologation purpose in your car
(except the bigger blue VSV, this is the OEM boost controll selenoid)
greetz
This post has been edited by Sunny: Sep 17, 2011 - 11:02 AM
KEEP COOL UNDER PRESSURE
post Sep 17, 2011 - 8:20 PM
bsamps4
Joined May 16, '10
From Raleigh
Spec 2+ clutch kit is officially on it's way. Weight balancing here I come!
post Sep 20, 2011 - 2:07 PM
bsamps4
Joined May 16, '10
From Raleigh
Here is the first batch to arrive this week. Goodies from Toyota. I'll list part numbers out below the picture for reference.
Distributor Cap: 19101-88364
Distributor Rotor: 19102-74040
2nd Gen Plug Wires (yes these fit the 3rd gen): 90919-21536
Timing Belt: 13568-79105
Seal Packing: 00295-00103
Hydraulic Timing Belt Tensioner: 13540-88480
Full Oil Pump Assembly: 15100-88460
Full Water Pump Assembly: 16100-79236
Complete Engine Overhaul Gasket Kit: 04111-74541
post Sep 21, 2011 - 10:13 AM
bsamps4
Joined May 16, '10
From Raleigh
Just got a call from the machine shop. The block has been cleaned, and new freeze plugs installed. The guy also mentioned that the block was warped between .002 and .003. That's not a lot of warpage, but I want it perfect. Right now I'm waiting on pistons, clutch, bearings, and ARP hardware. Then I get to bring all the goodies up to the machine shop, and the real work begins!
post Sep 21, 2011 - 11:49 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Good shiz Ben!
Good to hear everything is coming along nicely, even with the warpage on the block, and that your progress is still going well.
Has no more Celicas
post Sep 21, 2011 - 12:14 PM
bsamps4
Joined May 16, '10
From Raleigh
Im looking forward to it Brian. She's gonna be MEAN!
post Sep 21, 2011 - 6:06 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
Your engine is garbage.
Na j/k, hurry up and start building it gosh. I am a little surprised it was warped 2 to 3 thou though.
post Sep 21, 2011 - 6:09 PM
bsamps4
Joined May 16, '10
From Raleigh
Shouldn't be too bad. That's only the width of a dog hair.
post Sep 24, 2011 - 10:04 AM
bsamps4
Joined May 16, '10
From Raleigh
Clutch Arrived! Pistons, Rods, Bearings, and Studs are delayed until Tuesday.
post Sep 26, 2011 - 11:45 AM
bsamps4
Joined May 16, '10
From Raleigh
Dropped the head off at the machine shop today to be pressure tested, cleaned, and 5 angle valve job. Got a sneak peek at my block while I was there. The new freeze plugs have been installed, and the block has been hot tanked.
post Sep 26, 2011 - 12:21 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Looking Good. Especially love the Toyota logo looking clean and proper.
Has no more Celicas
post Sep 26, 2011 - 9:25 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
WIN!!!
post Sep 28, 2011 - 4:06 PM
bsamps4
Joined May 16, '10
From Raleigh
Yesterday morning I barely tripped over all the parts in front of my door. So I went ahead and took a picture for you guys, but all parts have been taken to the machine shop. The head has already been cleaned, and a valve job performed. I'll get pics when I get it back. I should have the whole assembly back in the next week or so, and the build begins!
post Sep 28, 2011 - 5:49 PM
win.
good stuff man!
post Sep 28, 2011 - 6:33 PM
Ted95
Joined Mar 8, '09
From Westport, MA
sweet build man
Lo-Fi Version Time is now: February 16th, 2025 - 11:57 PM
