51 Pages V  « < 20 21 22 23 24 > »
> Green Bullet ST205 Re-Born, MODIFICATIONS, AND UPDATES!
post Apr 22, 2012 - 4:43 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
stock ecu, no fuel tuning?? the extra 20-30cc from the 86.5 pistons / .020 overbore doesnt matter? or is there any stage where you would lean out? suppose you wouldnt know either?
just asking, your engine build sounds identical to mine except i went for je pistons instead of wiseco
Mike W
269awhp / 273ft-lbs
post Apr 22, 2012 - 4:48 PM
bsamps4
Joined May 16, '10
From Raleigh
I haven't had any lean situations at all. I doubt the slight overbore really matters too much in that respect. My Africa reader stays right between 13-14. The bump in compression is a nice advantage, but no I have no fuel management and running stock Ecu.
post Apr 23, 2012 - 10:45 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (bsamps4 @ Apr 20, 2012 - 7:43 AM) *
I just received the kirkosaurus mounts. I need to put those in to see if maybe that helps a little too. I'm planning on running ST sway bars, and the 185 links.
those are great!
QUOTE (delusionz @ Apr 22, 2012 - 5:43 PM) *
u know that IS a good question... my cylinder has been bored .020 but i get the weird lean issue when cruising though, not when on gas
post Apr 23, 2012 - 11:34 AM
bsamps4
Joined May 16, '10
From Raleigh
Mine doesn't lean out....
post Apr 25, 2012 - 10:38 AM
bsamps4
Joined May 16, '10
From Raleigh
I re-installed my TRD 3 point bar. So here are a few pics. I also installed the Kirkosaurus mounts, and I wanted to freaking KILL myself on that rear mount! It only took me 15 minutes to do the front. I think i'm going to have to buy a new rear mount though because the two studs on the back mount miraculously stripped themselves. FML! Here are pics anyways.
post Apr 25, 2012 - 11:38 AM
rave2n
Joined May 29, '09
From Gainesville, FL
I hate that mount!
post Apr 25, 2012 - 11:42 AM
Ted95
Joined Mar 8, '09
From Westport, MA
that mount sucksss! glad to see the TRD Bar fitting well! mines still touches a little too =/
This post has been edited by Ted95: Apr 25, 2012 - 11:42 AM
st205 powered ss3 coupe
post Apr 25, 2012 - 11:46 AM
bsamps4
Joined May 16, '10
From Raleigh
I'm going to redesign a custom throttle bracket. 20 bucks shipped for anyone interested! And that rear mount can eat a d!$%!!! I can't stand the damn thing. Held me up for 3 hours the other day!
post Apr 25, 2012 - 12:13 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (bsamps4 @ Apr 25, 2012 - 10:46 AM) *
I'd be interested.
I'm also putting in the Kirk poly mounts, but I'm doing it while the engine is OUT of the car... should make it easier, yeah?
post Apr 25, 2012 - 1:10 PM
bsamps4
Joined May 16, '10
From Raleigh
I don't think its really going to be any easier. All the steps to do it with the engine in are about the same with the engine out. Either way you look at it that rear mount will be problematic.
post Apr 25, 2012 - 1:18 PM
Ted95
Joined Mar 8, '09
From Westport, MA
im trying to get a throttle body plate like the ATS one for the 2nd gen made up to get rid of the the fatory silicone coupler. i want it so its angled a tad so it clears the TRD bar.
post Apr 25, 2012 - 1:22 PM
bsamps4
Joined May 16, '10
From Raleigh
Ted, I will try to make one of those too. Would just need to create a gasket for it.
post Apr 29, 2012 - 2:31 PM
bsamps4
Joined May 16, '10
From Raleigh
Got some more work today. I created a new throttle bracket for use with my TRD tower bar, re-mounted my TRD bar, and modified the back end of my car so that my exhaust would quit bumping against it. Here are some pics!
post Apr 29, 2012 - 5:00 PM
bsamps4
Joined May 16, '10
From Raleigh
Here is the exhaust clip! 3 minutes of bliss!
http://www.youtube.com/watch?v=wGbppkUOV_o...eature=youtu.be
post Apr 29, 2012 - 9:16 PM
jcbass7
Joined Apr 20, '06
From Florida
Just read this entire thread, awesome swap, super clean! Inspiration for me to get back in the garage and get my 3S into the car. biggrin.gif
PS: That rear mount is my least favorite thing in the whole engine bay, it blows.
post Apr 29, 2012 - 11:27 PM
Culpable04
Joined Apr 17, '06
From New Jersey
when I was putting the engine on the blue car, I spent a little over an hour trying to get that rear mount in place, gave up and went home, next day after work, went back to give it another shot and 5 minutes later it was in laugh.gif
as bad as it is, I think I have it under control now, I can take it out and back in in less than 20 minutes with no issues anymore.
post Apr 30, 2012 - 12:29 AM
Box
Joined Feb 23, '12
From Warrior, AL
Exhaust sounds great! I still get a kick out of your BOV. "CHOOOOOOOO" Makes my day every time.
2001 Miata LS 5-speed
post Apr 30, 2012 - 5:55 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (Box @ Apr 30, 2012 - 1:29 AM) *
HAHA! me too! It's actually the factory NOV!
QUOTE (Culpable04 @ Apr 30, 2012 - 12:27 AM) *
^^ I envy you!
post Apr 30, 2012 - 7:14 AM
Nial
Joined Aug 25, '08
From England
I would remove the washers from under your strut brace, If its a clearance issue, make up an alloy plate the same size as the strut tower top.........it really needs its full surface area as a contact patch.
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post May 5, 2012 - 11:53 AM
celica74
Joined Feb 8, '10
From North Carolina
QUOTE (bsamps4 @ Apr 29, 2012 - 5:00 PM) *
I like it. No raspy or too loud. Just right. Engine bay looks great. Cant wait to see it in 2 weeks
Lo-Fi Version Time is now: December 2nd, 2024 - 3:51 AM
