Green Bullet ST205 Re-Born, MODIFICATIONS, AND UPDATES! |
Mar 22, 2013 - 7:21 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
a spacer that will just slide in and fill in that gap between the rotor and hub center right? Yea a hub centric ring. Same thing you're referring to I believe. -------------------- |
Mar 22, 2013 - 8:17 AM |
hah just wanted to make sure we were one the same page. I have talked with people in the past who confused hub centric rings with hub centric spacers.
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 22, 2013 - 10:37 AM |
Yup, those are in the mail as we speak. I should probably check my mailbox....
I have received brand new floor mats, and the gt4 bumper seal that I should have a chance to install this weekend! -------------------- |
Mar 22, 2013 - 4:31 PM |
Enthusiast Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
Is that before or after we get my motor in and bobby's done?
Mar 25, 2013 - 7:35 AM |
Just a heads up guys. If anyone is looking for my 5sfe to 3sgte wiring thread it's been added to the stickies in the forced induction section.
Mar 29, 2013 - 4:36 PM |
Those are actually XXR 530 if I'm not mistaken. The 527 don't have the mesh look.
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Mar 29, 2013 - 4:38 PM |
Those are actually XXR 530 if I'm not mistaken. The 527 don't have the mesh look. Good catch. You're right! -------------------- |
Apr 26, 2013 - 8:44 AM |
Any body aware of which fittings on the throttle body and intake manifold that can acutally be unscrewed and replaced with AN lines??? It looks like most all of them are press fit.
May 3, 2013 - 3:32 PM |
Little fun for all you eagle eyes out there.
Can you spot the differences between the two pictures? -------------------- |
May 3, 2013 - 3:42 PM |
Strut bar is black, the bottom picture looks a bit neater. That's all I have time to spot for now.
May 3, 2013 - 7:09 PM |
Enthusiast Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
The lightings a little different id say its a bit later in the day, maybe like, the suns starting to come down a bit and slightly less overcast, the ground looks a little drier now, possibly you moved the car forward a bit and someone has parked in the top right. Photos taken from about a 45o angle, a bit lower than the previous shot.
And the strut bar no longer has rust. |
Jun 13, 2013 - 8:13 AM |
The demise of Bobby's transmission (e153) has led me to a new chapter. Bobby let me pick up the scrapped e153 from him, that has already been partially disassembled by a transmission shop. My goal is to repair the damage (looks like wrecked bearings), and to replace the factory differential with a Quaife unit. No pictures at the moment, but they will be coming soon as I make my progress on the complete tear down and rebuild of this e153 transmission.
Stay posted! -------------------- |
Jun 14, 2013 - 8:42 AM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
I had a feeling you would scoop that tranny up, good luck man!
-------------------- st205 powered ss3 coupe
Jul 7, 2013 - 1:50 PM |
So i got started getting the transmission apart today, and was able to completely tear it down. Here are some picks. Looks like I've got my work cut out for me!
Now all I need to do is replace the torn up bearings, wash all the components, and make sure the oil pump isn't jammed with metal debris, and then hopefully the re-assembly will begin after close inspection of all of the components. -------------------- |
Jul 9, 2013 - 3:45 PM |
Enthusiast Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) |
Dang man, can't believe I've just now seen this epic build thread. Awesome work dude! Hopefully I can make the next Raleigh meet. I am trying to get motivation to get my celica back on the road again. It's been sitting for quite some time
Jul 9, 2013 - 10:08 PM |
i dont see where the damage is. do you have pics...
Jul 10, 2013 - 5:33 AM |
The second picture from the top. If you look right below the last gear...that was once a bearing.
Aug 20, 2013 - 10:12 AM |
Well a few small updates on the way, but here is one that has pictures.
I had my windshield tinted because the tint strip that was on the car when I got it was beginning to peel. Coming up next is a new primary radiator fan by SPAL, breather for my a/c idle up vsv, filter for my synapse bov, and a new adapter for my radiator hose for my coolant temp sensor. Before: After: This post has been edited by bsamps4: Aug 20, 2013 - 10:25 AM -------------------- |
Aug 20, 2013 - 11:43 AM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
I think the Before/After are reversed, Ben...
It looks really good. Very nice. Any updates on the transmission? -------------------- Has no more Celicas
Aug 20, 2013 - 2:16 PM |
Waiting on some press tools that I need to break the inner race of the blown bearing loose.
Lo-Fi Version | Time is now: November 29th, 2024 - 10:35 PM |
