51 Pages V  « < 38 39 40 41 42 > »
> Green Bullet ST205 Re-Born, MODIFICATIONS, AND UPDATES!
post Jan 19, 2014 - 6:42 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
Very nice, Ben - looks better and better each time.
Did you finish putting in the new valve springs?
Has no more Celicas
post Jan 19, 2014 - 7:04 PM
bsamps4
Joined May 16, '10
From Raleigh
bad boy!
post Jan 19, 2014 - 7:10 PM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (njccmd2002 @ Jan 19, 2014 - 8:04 PM) *
bad boy!
It was cracked everywhere and the grill was busted. There was no turning back. Would have made a terrible ss4 conversion.
post Jan 19, 2014 - 7:11 PM
Ted95
Joined Mar 8, '09
From Westport, MA
Does the new wastegate location sit lower then top of the fenders to be able to clear a stock hood, or does the wastegate sit above the top if the fender?
The gt4 hood obviously allows you more space tho with the rise in the hood, just wondering cuz I know for instance my stock hood is very tight with my IC piping.
st205 powered ss3 coupe
post Jan 19, 2014 - 7:13 PM
bsamps4
Joined May 16, '10
From Raleigh
It sits below. Couple of inches clearance!
post Jan 20, 2014 - 6:40 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (bsamps4 @ Jan 19, 2014 - 7:04 PM) *
Jeez, after all that effort to avoid that fate, I'm sorry to hear it.
So, new gasket and a throttle body cleaning while it's off I guess.
Has no more Celicas
post Feb 17, 2014 - 8:45 AM
bsamps4
Joined May 16, '10
From Raleigh
A few quick questions...I'm sure I'm not the only one exploring this option here...
I'm getting a 4th gen manifold to put on my 3rd gen. The guys is including the 4th gen throttle body and iac etc.
What are my options as far as getting this to work? I'm running factory 3rd gen ecu. I also have no interest in modifying the manifold to work with a 3rd gen throttle body.
Is the 4th gen IACV plug and play, if not what needs to be done to get it to work?
Do 4th gen injectors work with 3rd gen electronics? Are the connectors the same? Are they the same impedance, or will I have to adapt my 3rd gen injectors and fuel rail to work with the manifold.
Has anyone ever blocked off the IACV and removed it entirely? If so, will this cause a check engine light? Will the car perform terribly until warm?
Anything else that you can think of that I haven't thought of that might throw a wrench in my plans?
post Feb 17, 2014 - 9:01 AM
Neon90424
Joined Jan 19, '11
From what I can gather from my 4th gen 3sgte the injectors are top feed, thats about as much as I can remember
post Feb 17, 2014 - 10:26 AM
QUOTE (bsamps4 @ Feb 17, 2014 - 8:45 AM) *
Injector information and maybe some helpful additional information:
http://www.6gc.net/forums/index.php?showtopic=67576
http://www.gt4dc.co.uk/forum/viewtopic.php?f=1&t=6831
In general i would search that forum for information.
(ST215 related info: http://www.gt4dc.co.uk/forum/viewtopic.php...hilit=sidefeed)
post Feb 18, 2014 - 9:41 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
The 4th gen injectors are high impedance, 3rd gen are low impedance. If you want to use the 4th gen injectors and 3rd gen ECU, simply bypass the injector resistor box. I would use the 4th gen injectors and fuel rail.
For the IACV, if you use the 3rd gen ECU and the 4th gen IACV, you will need to send the pin RSO to ground, not to the RSO pin of the ECU as the 4th gen IACV do not act the same as the 3rd gen one. Maybe you can swap the 4th gen IACV for the 3rd gen one, don't know.
Sam
post Feb 24, 2014 - 8:27 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (pitcelica @ Feb 18, 2014 - 9:41 PM) *
Sam
Could you give me more detail on using the 4th gen IACV? I get the part about changing the RSO pin to ground, but what do you do with the wire left over from the ECU? Do you ground that too?
post Feb 25, 2014 - 8:06 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
I think I made a mistake. On the gen4 wiring, the IACV RSC pin is sent to ground (pin #3 on the IACV connector (brown wire)). The RSO pin (pin #1 on the IACV connector (black wire)) goes to the ECU. On the 4th gen ECU, it goes to pin #18 of the 31 pins ECU connector. On the gen3 ECU, the RSO pin is pin #10 of the 26 pins ECU connector.
post Feb 27, 2014 - 9:00 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (pitcelica @ Feb 25, 2014 - 8:06 PM) *
So basically all I need to do is ground the RSC wire to the intake manifold ground and call it a day?
post Mar 1, 2014 - 12:06 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
I wanna come see it! Lol
I'm in town for the next week or so and need to find something to do, people to see, places to visit. lol
-Alex {](O_o)[}
post Mar 1, 2014 - 3:01 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
youre gonna be in raleigh?!
post Mar 1, 2014 - 8:15 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Dude, I currently am in raleigh. I'm about to head to Cars & Coffee in Cary in like 5 minutes.
-Alex {](O_o)[}
post Mar 1, 2014 - 8:16 AM
bsamps4
Joined May 16, '10
From Raleigh
I live really close to where they have cars and coffee.
post Mar 1, 2014 - 11:37 AM
Keiri
Joined Mar 6, '04
From Charlotte, NC
We should all get together next Friday or something before you leave Alex.
Has no more Celicas
post Mar 1, 2014 - 5:07 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (Keiri @ Mar 1, 2014 - 11:37 AM) *
I'm down. My girlfriend's trying to get me to come home sooner though cuz SXSW (South by Southwest) in Austin is happening next weekend.
Cars & Coffee was cold this morning. -__- Not as massive as I was used to back home, but not a bad turn out. I was like, "Where the Supras?" lol
-Alex {](O_o)[}
Lo-Fi Version Time is now: November 26th, 2024 - 8:28 AM
