Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) ![]() |
The turbo also looked cold so I got it blanket. Enjoy! Did you tuck it in and read it a story? ![]() Lol...nope...i hear when they're warm that they will sing to you ![]() This post has been edited by bsamps4: Feb 13, 2015 - 11:41 AM -------------------- ![]() |
Alright guys! Cross your fingers for me! Matt, Brian and Jason are coming up tomorrow to work on some final preparatory touches so that we can start the engine for the 2nd first start! Looking forward to seeing how it idles, and how the new cam's sound, but it hasn't started in over a year, and I'm a bit nervous for this first start!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) ![]() |
I'm excited!
![]() We should be up there by 11:30AM - probably leaving here around 9AM or so. -------------------- Has no more Celicas
Sounds like a plan. Still lots of little things to do. I should probably make a list.
Finish wiring to TPS AND IACV Secure IACV to throttle body Connect breather to vacuum line Connect Fuel Return Install intake manifold struts install factory boost controller wire cooling fans fix positive battery terminal charge battery tighten water and oil lines to turbo install new clutch line clock turbo down vacuum out remaining glass ...if I think of anything else i'll add it here -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) ![]() |
woohoo!
woohoo! HAHA a good majority of the stuff on the list is small, but a huge PITA! Still looking forward to hearing it idle. -------------------- ![]() |
Soooo??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
Everything is pretty much done going g to be starting up to test in a bit. Ben says turbo clocking comes later
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
better post a vid
Couldn't have done it with all the help! Brian, Matt, Alyssa, and Jason were incredible!!! So here we go! Here are a few of the pictures, and I will post more as I receive them, but this was a huge breath of fresh air!
We took care of everything on the previous list! Video is here...! http://youtu.be/dvjm163fJq4 ![]() ![]() ![]() ![]() ![]() ![]() -------------------- ![]() |
damn that cam makes it sounds amazing
Question of concern..
Will the wastegate hit the radiator because of the front to back movement of the engine? Looks awfully close.. This post has been edited by mkernz22: Feb 15, 2015 - 8:42 PM |
Woooooo! Doesn't sound bad for a four cylinder, amazing what a turbo and some cam can do.
Question of concern.. Will the wastegate hit the radiator because of the front to back movement of the engine? Looks awfully close.. We thought about that too. I mocked it up with a factory rad. I guess im just crossing my fingers for now. -------------------- ![]() |
Being the engine is already angled quite severely in the direction the motor would rock to, the mounts would have to be pretty crappy to let it rock past the point of its resting position. That being said I'd feel more comfortable with more space myself, just becomes a matter of the wastegate or radiator being easier to reposition.
Being the engine is already angled quite severely in the direction the motor would rock to, the mounts would have to be pretty crappy to let it rock past the point of its resting position. That being said I'd feel more comfortable with more space myself, just becomes a matter of the wastegate or radiator being easier to reposition. The wastegate would definitely be easier to move, however, the cost of doing so might be a little high since you would have to fab and coat new piping for it.. Not sure what mounts are in there, but if you have the poly replacements (not inserts), then I feel like you might be able to get away with it being that close. **Went back and saw a pic of the inserts. You might just be able to get away with it, but it'll be close ![]() This post has been edited by mkernz22: Feb 16, 2015 - 9:29 AM |
If it comes down to moving it then I will, but the motor doesn't move much with the mounts in it, but if I notice that it starts marring up the wastegate and
the radiator, then I will take care of it then. For now I'm going to let it roll, and see what happens. -------------------- ![]() |
Sounds excellent. Aren't you concerned about revving when the oil isn't fully circulated?
'93 MX-5 LE |
Sounds excellent. Aren't you concerned about revving when the oil isn't fully circulated? I primed the engine first before I started it. -------------------- ![]() |
Lo-Fi Version | Time is now: February 18th, 2025 - 11:09 AM |
