FOUND! |
FOUND! |
Jan 9, 2011 - 4:58 PM |
Enthusiast Joined Dec 7, '10 Currently Offline Reputation: 1 (100%) |
FOUND!
Another big thanks to 6gc! This post has been edited by TheChildOfTheSea: Jan 15, 2011 - 12:10 AM |
Jan 9, 2011 - 9:14 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Hey bro - welcome aboard.
Not sure what lenses you may be talking about, but I know you're not the only one with that problem. It plagues us all. This article might be of some use to you: Modify JDM Projectors for LHD Use If you have any questions about this retrofit, please post in the "Exterior" section. Good Luck! -------------------- |
Jan 9, 2011 - 11:21 PM |
Interesting guide, thanks! but I don't understand it at all!
What I mean by lens is the glass part |
Jan 10, 2011 - 2:57 AM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
You don't need the lens. The USDM lens has diffusers in it so it isn't clear like the JDM lens. The link that KAOS posted is to adjust your JDM projectors to aim them properly, which is all you need to do. Your lights are pointed to the left right now? All you need to do is pop your hood and there is a screw on the lights. You can aim your headlights properly with nothing more than a screwdriver. You don't need to buy anything at all.
Edit: I assumed you had JDM projectors, but your post merely says "JDM Headlamps." The early model JDM lights were similar to the USDM headlights, with the diffusers in the lenses. With either the early model JDM lights or the projectors, all you need to do is aim your lights. It's easy. There's a long screw on top for horizontal adjustment, and towards the bottom of the light, there is another screw for vertical adjustment. This post has been edited by richee3: Jan 10, 2011 - 2:59 AM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jan 10, 2011 - 9:50 AM |
Edit: I assumed you had JDM projectors, but your post merely says "JDM Headlamps." Whoops - x2, my apologies. -------------------- |
Jan 10, 2011 - 5:22 PM |
You don't need the lens. The USDM lens has diffusers in it so it isn't clear like the JDM lens. The link that KAOS posted is to adjust your JDM projectors to aim them properly, which is all you need to do. Your lights are pointed to the left right now? All you need to do is pop your hood and there is a screw on the lights. You can aim your headlights properly with nothing more than a screwdriver. You don't need to buy anything at all. Edit: I assumed you had JDM projectors, but your post merely says "JDM Headlamps." The early model JDM lights were similar to the USDM headlights, with the diffusers in the lenses. With either the early model JDM lights or the projectors, all you need to do is aim your lights. It's easy. There's a long screw on top for horizontal adjustment, and towards the bottom of the light, there is another screw for vertical adjustment. yes, I've got JDm lights right now and they are pointed to the left. So all I need is to adjust them? so those guides are only for the USDM lights? |
Jan 10, 2011 - 5:33 PM |
The link that KAOS posted is for JDM projector headlights. I'm not sure if you have JDM projectors or just JDM headlights, which are similar to USDM headlights. If you have the JDM/USDM headlights, all you need to do is adjust them.
Jan 10, 2011 - 7:26 PM |
The link that KAOS posted is for JDM projector headlights. I'm not sure if you have JDM projectors or just JDM headlights, which are similar to USDM headlights. If you have the JDM/USDM headlights, all you need to do is adjust them. They are JDM/JDM...directly from a front clip! and they illuminate too low, I can't see anything! |
Jan 10, 2011 - 7:35 PM |
Are they projectors or not?
Jan 10, 2011 - 10:28 PM |
Jan 10, 2011 - 10:42 PM |
ohhh, ok.
well if they are too low (one of mine is) you will have to take the bumper off to readjust the bolts because i bolted mine on too low. the screws only make the lights go left to right, well that's what it says on them... |
Jan 10, 2011 - 11:16 PM |
Ok so for the left to right, I only need to adjust them, and for up and down, I need to adjust the bumper...
Then why was I told I had to change the glass lens to USDM ones, because the JDM ones are meant to illuminate the left side... |
Jan 10, 2011 - 11:27 PM |
No you have it all wronggg
You don't have to change any glass at all. The JDM Projectors illuminate to the left side. You don't have projectors. You don't adjust the bumper, you have to take the bumper off to adjust the bolts or frame part that the headlights bolt down to. |
Jan 10, 2011 - 11:33 PM |
Ah ok! and I can adjust them to illuminate straight ahead too?
Jan 11, 2011 - 9:20 AM |
Enthusiast Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
You don't need the lens. The USDM lens has diffusers in it so it isn't clear like the JDM lens. The link that KAOS posted is to adjust your JDM projectors to aim them properly, which is all you need to do. Your lights are pointed to the left right now? All you need to do is pop your hood and there is a screw on the lights. You can aim your headlights properly with nothing more than a screwdriver. You don't need to buy anything at all. Edit: I assumed you had JDM projectors, but your post merely says "JDM Headlamps." The early model JDM lights were similar to the USDM headlights, with the diffusers in the lenses. With either the early model JDM lights or the projectors, all you need to do is aim your lights. It's easy. There's a long screw on top for horizontal adjustment, and towards the bottom of the light, there is another screw for vertical adjustment. I just read the post of how to make the lights LHD..if I have regular jdm head lights not projectors.. Do I still have to open it like the post on the top says? Or just adjust them using only the screws? -------------------- |
Jan 11, 2011 - 9:26 AM |
Ah ok! and I can adjust them to illuminate straight ahead too? If you loosen the bolts that are used to mount the headlights, you can adjust adjust them up and down. It's easier if it is at night and you shine them at a wall. You don't need the lens. The USDM lens has diffusers in it so it isn't clear like the JDM lens. The link that KAOS posted is to adjust your JDM projectors to aim them properly, which is all you need to do. Your lights are pointed to the left right now? All you need to do is pop your hood and there is a screw on the lights. You can aim your headlights properly with nothing more than a screwdriver. You don't need to buy anything at all. Edit: I assumed you had JDM projectors, but your post merely says "JDM Headlamps." The early model JDM lights were similar to the USDM headlights, with the diffusers in the lenses. With either the early model JDM lights or the projectors, all you need to do is aim your lights. It's easy. There's a long screw on top for horizontal adjustment, and towards the bottom of the light, there is another screw for vertical adjustment. I just read the post of how to make the lights LHD..if I have regular jdm head lights not projectors.. Do I still have to open it like the post on the top says? Or just adjust them using only the screws? You don't have to do anything to the non projectors. |
Jan 11, 2011 - 9:40 AM |
Enthusiast Joined Nov 20, '04 From Carlisle, PA Currently Offline Reputation: 27 (100%) |
You have two long silver adjustment bolts sticking out the back of the headlamp, one near the top and one near the bottom. One bolt does horizontal and one does vertical alignment. The bolts are 8mm. Use a ratchet wrench or socket - not a wrench. Either way, it's not going to illuminate the road correctly with those RHD headlights because the glass is directing the light toward the wrong side - you're not going to get it up on the right side without raising it up very high on the left side - blinding traffic, so you're right in assuming you need to buy new low-beam headlights.
I assume these came on an imported '94 GT-Four to Canada? Once you get the low-beam headlights, you'll be set. In the meantime, raise them a little so you can see, but not too high or you'll be blinding everyone you drive past. |
Jan 11, 2011 - 9:43 AM |
I just read the post of how to make the lights LHD..if I have regular jdm head lights not projectors.. Do I still have to open it like the post on the top says? Or just adjust them using only the screws? You should remove those RHD reflector low-beam headlights, drop them in the trash, and buy ones that are LHD. You went a step BACKWARD going with those. That's like swapping a 3sfe into your Celica - "JDM" - yes, better - no. |
Jan 11, 2011 - 12:39 PM |
even if you adjust the 8mm bolts behind the headlights, you will still have a similar cut off light pattern that points higher towards oncoming traffic. although they don't blind oncoming traffic as bad as projectors so i wouldn't worry too much about getting pulled over. but if you're concerned about DOT stamping, a real fix would be to swap the lenses, or just replace the whole headlight assembly with a LHD set. the only benefit of having the jdm non-projector lamps are the little parking lights integrated in the housing.
Jan 11, 2011 - 8:27 PM |
You have two long silver adjustment bolts sticking out the back of the headlamp, one near the top and one near the bottom. One bolt does horizontal and one does vertical alignment. The bolts are 8mm. Use a ratchet wrench or socket - not a wrench. Either way, it's not going to illuminate the road correctly with those RHD headlights because the glass is directing the light toward the wrong side - you're not going to get it up on the right side without raising it up very high on the left side - blinding traffic, so you're right in assuming you need to buy new low-beam headlights. I assume these came on an imported '94 GT-Four to Canada? Once you get the low-beam headlights, you'll be set. In the meantime, raise them a little so you can see, but not too high or you'll be blinding everyone you drive past. Yeah, my celica is imported from japan, so I've got the JDm lights, this is why I am shopping only for the glass lenses... I just read the post of how to make the lights LHD..if I have regular jdm head lights not projectors.. Do I still have to open it like the post on the top says? Or just adjust them using only the screws? You should remove those RHD reflector low-beam headlights, drop them in the trash, and buy ones that are LHD. You went a step BACKWARD going with those. That's like swapping a 3sfe into your Celica - "JDM" - yes, better - no. What I said |
Lo-Fi Version | Time is now: November 26th, 2024 - 12:39 PM |
