> Removing rear license plate bezel(coupe)
post Jan 9, 2011 - 7:43 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
I just talked to a few people about removing the rear license plate bezel, and no one had a 100% answer.i did it on a coupe and im not sure if its different on the hatch or not. So here is how to remove it:
1: Remove the plastic strip above the latch. Just pry it upward as there are only 6 clips that hold it in.(also remove your license plate)
2.Remove tail lights(3 10mm bolts for the coupe)
3.Remove the 2 10mm screws on the to right and left of bezel(red is the clips,black is the bolts)
4.Push bezel arms inward so they disconnect from the body clips(very obvious)
5.Pull the 2 bottom clips out of the body of the trunk(still attached to bezel)
6.Remove the license plate bulb bulbs(spin them)
Install by just reversing the steps.
This post has been edited by SupraKid: Jan 9, 2011 - 11:54 PM
post Jan 9, 2011 - 10:43 PM
DEATH
Joined Dec 19, '07
From tx
Add to how-to's for future use [?] and give this man a no-prize [Holla if you get that reference biggrin.gif ]
This post has been edited by DEATH: Jan 9, 2011 - 11:12 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
Lo-Fi Version Time is now: January 12th, 2025 - 7:00 PM
