> turbo help
post Jan 11, 2011 - 12:03 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
Im not the biggest turbo geek, this rly is my 1st turbo i ever played with so with that said im curious to know why my turbo looks like this and what needs to be done.
as you can see it doesnt look so pretty
I only want to be faster than the guy next to me.
post Jan 11, 2011 - 12:36 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
do you have a high oil consumpion of the engine?
possible reasons are:
- damaged shaft seal of the turbo
- pressure in the crank case (piston rings) -> the oil comes from the crank case ventilation
- or if your engine does not need many oil it is also from the ventilation but the reason is just high miles on the engine
greetz
This post has been edited by Sunny: Jan 11, 2011 - 12:37 PM
KEEP COOL UNDER PRESSURE
post Jan 11, 2011 - 1:51 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
looks ok to me. you are going to get some oil residue, but i dont see anything that really causes me concern
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 26, 2011 - 11:13 PM
Gary
Joined Aug 28, '04
From FLA USA
Doesn't look too bad at all. Check for oil inside your IC and check both directions of shaft play.
_Gary
Lo-Fi Version Time is now: November 23rd, 2024 - 11:29 AM
