Air-con Control Unit |
Jan 13, 2011 - 6:30 AM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
Hey, I've been having problems with the air con unit, the top lights cut out and if you hit the side they come back on, you can also turn them off by hitting the side haha (I've taken both the rear plugs out and put back in again, still the same)
Also the actual air-con won't blow air ocastionally yet every button works and you can hear the vents moving and you can hear the compressor, its just the turning on that doesn't work, when you select it to let the outside air in it works although only on the off position. Then it will randomly start working again. So I'm guessing its the control unit that is playing up and am just wondering if anyone else has had similar problems? |
Jan 25, 2011 - 10:05 PM |
Enthusiast Joined Oct 21, '05 From Okinawa, Japan Currently Offline Reputation: 0 (0%) |
I have had the same problem and just got a new unit from the JY. The new one works fine so it is something in the wiring for the old HVAC controls that caused it to work intermittently. I am currently taking apart the old one to try to figure out where the short or whatever is at. Good luck!
-------------------- -Dan
1998 SSII Beams, work in progress... |
Jan 26, 2011 - 4:05 AM |
Enthusiast Joined Jan 22, '07 From Loveland Currently Offline Reputation: 4 (100%) |
If interested, I have an HVAC control unit from the junk yard available. PM me if you want it.
Lo-Fi Version | Time is now: November 27th, 2024 - 4:58 AM |
