2 Pages V  < 1 2
> 5sfe stops pulling above 4k rpms, :[ All you gearheads help me out!
post Mar 6, 2011 - 12:48 AM
DGolden32
Joined Apr 28, '09
From Auburn, AL
It is attached to the inside wall of the drivers side wheel well rear of the air cleaner. About thigh high. Let me know if it worked!
Oh, and definitely try this before timing, for alas, the filter is only $24
This post has been edited by DGolden32: Mar 6, 2011 - 12:51 AM
post Mar 6, 2011 - 4:47 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (presure2 @ Feb 7, 2011 - 8:36 AM) *
QUOTE (stephen_lee @ Feb 1, 2011 - 3:08 PM) *
guys the 5s is at an angle, so the cams will be a bitch to set. PLUS you have to make sure theyre lined up with eachother. im betting thats both your issues
move timing one tooth forward, test
move timing back 2 teeth, test.
im wondering if the cams are in there correctly.
mike, did you follow the BGB for installing the cams, following the matchmarks on the slave gears?
seeing this a little late lol
i just got back home for break and im thinking its the fuel filter. just maybe.
everything is lined up perfectly. the only thing (which i had mentioned before) that might be off is the U notch alignment. im not positive, but it could be
エキサイティングカーレーシングチーム!
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 28th, 2024 - 11:34 AM
