3 Pages V   1 2 3 >
> new question, cranking but won't start, and a plug and something e, HELPPPPPPPP
post Jan 18, 2011 - 4:17 PM
NOVAKx17
Joined Oct 7, '09
okay, as some of you may know i swapped my 94 engine into my 97 st with only minimal changes as switching over all
the accessories and intake.
and now that i'm wiring it all back together and running all the hoses and vaccume lines, i noticed some of the places where
hoses should be ran there are some caps on the intake?
i don't know if i should take them off and run hoses or leave them on? one is on the top of the intake, and the other is on the bottom....
if it helps the 97 was a standard, and the 94 was an auto....
also, does anyone have some close of pictures of where all the hoses/vac lines go? i know i was told to just look at the diagram on the firewall,
but that can be confusing at times , and it doesn't have all of the hoses...
also there is one other thing i'm curious of, over by the power steering pump on the bottom passenger side, there is a long hose/tube that comes from the driver side and has an open hole/connecter on the end, kind of looks like the same thing as the shifting cable ends..... but i don't know where it goes either...
i can try and get pictures up later, but i still cant find my camera... so some pictures of how its all supposed to be ran would be very much appreciated.. thanks guys
This post has been edited by NOVAKx17: Jan 21, 2011 - 9:34 PM
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Jan 18, 2011 - 5:03 PM
mkernz22
Joined May 10, '10
From MA
who need vac lines? just cap them all off haha
just kidding. don't do that.
but i'll answer one of your questions, the auto to manual doesn't make a difference because it's the engine and not the tranny
post Jan 18, 2011 - 5:09 PM
NOVAKx17
Joined Oct 7, '09
i was thinking the only difference might of been one had something to do with cruise control maybe?
NOVAKx17
post Jan 18, 2011 - 5:24 PM
mkernz22
Joined May 10, '10
From MA
I wouldn't think so cause with the 5s, i took the cruise off a 97 celica, both auto, but the manual 94 i have, the cruise looks the same.
That's the 5s though, the 7a could be setup different but the cruise control shouldn't affect the vac lines
post Jan 18, 2011 - 5:30 PM
NOVAKx17
Joined Oct 7, '09
hmmm ... not sure but i would like to get this figured out today,
i got everything put back together and oiled up, only thing left to do is finish the vacume lines/hoses and
put in antifreeze and fire it up!
NOVAKx17
post Jan 18, 2011 - 6:16 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
i can go snap a pic if you still need it
post Jan 18, 2011 - 6:17 PM
NOVAKx17
Joined Oct 7, '09
that would be awesome if you don't mind.....
if you could take some close up ones that would be great!
mainly the ones on the driver side, and the ones on the back of the intake!
help is much apreciated!
NOVAKx17
post Jan 18, 2011 - 6:37 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
Can't get a good photo right now of driver's side its too dark.
but maybe this will help
post Jan 18, 2011 - 6:40 PM
NOVAKx17
Joined Oct 7, '09
thanks... yours is a little more clear than mine, but its still kind of hard for me to figure out by reading that, if anyone can help, i'd like to see the actual vaccume lines and where they go if anyone has some free time....
NOVAKx17
post Jan 18, 2011 - 6:43 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
start with the items on the picture that aren't the manifold and see what's missing...that sticker shows the lines and has the external engine parts shown in the location they are in the engine bay...if u start tracing the ones u already have hooked up ull figure it out in no time.
post Jan 19, 2011 - 10:10 AM
QUOTE (NOVAKx17 @ Jan 18, 2011 - 6:40 PM) *
the diagram makes it pretty simple, dude, just trace each line.
the ones that are essesial for the motor to run right are the air control vavle, map sensor, pressure regulator, throttle opener, and idle up valve (if you have AC.)
you can block off the others if you have a 94-96, and bridge the wires going to the egr temp sensor. 97+ may throw a code if you bridge it, im not sure.
post Jan 19, 2011 - 10:16 AM
NOVAKx17
Joined Oct 7, '09
wow, i'm dumb... is that little bar in the back on the top of the diagram the bar thats on the back of the intake?
if so, i can't believe i was having so many problems with this...
wow.
This post has been edited by NOVAKx17: Jan 19, 2011 - 10:17 AM
NOVAKx17
post Jan 19, 2011 - 5:31 PM
the one thats labeled "pipe" in the upper right of the diagram? if so, yes, that is the air bypass pipe that attaches to the back of the intake manifold.
post Jan 21, 2011 - 10:45 AM
NOVAKx17
Joined Oct 7, '09
Okay, thanks manny...
GOOD NEWS. i have all the vaccume lines ran right, and my engine is now turning over but not firing. ..
the only things i don't have hooked up are these and i need your help in knowing what they are....
any ideas?
this wire is over by the battery, (2 pictures of it.)
and this thing is all the way over and down by the power steering pump? where does it go?
also, any suggestions as to why its turning over but not starting?
NOVAKx17
post Jan 21, 2011 - 10:48 AM
the last pic, of the banjo fitting looks like the power steering pump hardline.
sorry, not too familiar with the 7a..
post Jan 21, 2011 - 10:50 AM
NOVAKx17
Joined Oct 7, '09
ok, so it goes to the power steering pump then?
k i'll get that taken care of..
but it is a sigh of relief that the car is now strongly turning over and wanting to fire!
NOVAKx17
post Jan 21, 2011 - 11:32 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
that connector looks like coil power.. ya might wanna plug that in on the dizzy.
post Jan 21, 2011 - 7:21 PM
NOVAKx17
Joined Oct 7, '09
no, it doesn't plug into the dizzy, there is one already plugged into the dizzy.
uhm. so i found out i'm not getting any spark to the cylinders though?
NOVAKx17
post Jan 22, 2011 - 8:15 AM
QUOTE (NOVAKx17 @ Jan 21, 2011 - 7:21 PM) *
there should be 2 plugs on your distributor.
one for the distributor itself, the other for the coil thats inside the distributor.
thats why you dont have spark.
post Jan 22, 2011 - 10:16 AM
NOVAKx17
Joined Oct 7, '09
really? i looked on the dizzy after he said that , and i didn't see another place for anything to be plugged in..... where is it located on the dizzy compared to the first one.
NOVAKx17
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 26th, 2024 - 3:50 AM
