15 Pages V  « < 4 5 6 7 8 > »
> GT-FOUR El Franjeado, EFR turbo etcq
post Apr 19, 2011 - 8:26 AM
Neon90424
Joined Jan 19, '11
This post has been edited by Neon90424: Jun 25, 2011 - 11:24 AM
post May 11, 2011 - 4:52 PM
Neon90424
Joined Jan 19, '11
I just ordered a BEE*R 2 stage Rev Limiter, should be here in 2-3 weeks, I know Ive seen an engine build on here with it, my question is how can I install this onto my car and over ride stock Rev limit and have the car rev atleast into 7.5 to 8k
post May 11, 2011 - 9:12 PM
Culpable04
Joined Apr 17, '06
From New Jersey
you just bought the wrong item,
this is to set your ignition cut instead of a factory fuel cut, so that your engine doesn't run lean during hard driving. it will in no way raise your red line,
post May 11, 2011 - 9:33 PM
Neon90424
Joined Jan 19, '11
I know that, I bought for the launch control aka Bang bang lol...I already have a FCD
my question is. How do i eliminate factory Redline and use BEE-R redline or is this ECU only territory
Oh and I read that it is wired to know when you step on the clutch and as soon as you let go it sets the ign cut back to what you have it set to...from what I know the 7gen celi starts via clutch so it must be some sensor the 6gc Does not have, I know it can be wired to the E-Brake I just know it will be more convenient launching with both hands on the wheel than with 1 on the E-brake , plus the feet hand eye butt coordination
This post has been edited by Neon90424: May 11, 2011 - 10:42 PM
post May 12, 2011 - 5:43 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
unfortunately theres no way to override the rev limiter without a standalone engine management system, which most come with launch control capability anyways.
sorry bud!
hows that turbo coming along? is it running yet?
Mike W
269awhp / 273ft-lbs
post May 12, 2011 - 1:10 PM
Neon90424
Joined Jan 19, '11
making the adapter took a very long time, infact its still not done, we had clearance issues with the radiator, but any time now it should be up and running...
post May 23, 2011 - 9:28 PM
Neon90424
Joined Jan 19, '11
tiny update
post Jun 16, 2011 - 6:53 PM
Neon90424
Joined Jan 19, '11
BUIIILD IIS ALMOOST FINISHED!!!
My review is as such...
My suspension is crap and it must be changed. The KKR 480 turbo is a bit laggy on the bottom end, I have yet to put the fuel cut defender and boost controller on the external wastegate. I get about 12 psi maybe in 2nd gear at tops... this thing once it gets to 4000 RPM is a monster after 10 psi its like it adds by 3 psi every second the boost controller shows it go to 13.7 psi in 4th gear and I got some shuddering at 5000 rpm maybe because I haven't calibrated the Water injection very well I may be drowning it as I am using the 350-400 horsepower injector (550cc) and the progressive pump has to be set to start around 5 psi and inject maximum to 25 psi so I dont drown it..
any input or questions anyone
EDIT
I checked the AEM manual and the 550 ml injector is good from 250-450hp so It cant be that and I dialed up max psi and I dont get that shudder anymore, I installed the Bee-R rev limiter and it sounds pretty bad ass! on my way home i tried a 4th gear pull and hit fuel cut twice, hit the boost controller warning of 19 psi and recorded a peak 20.2 psi. car turned off, i turned it on again, it turned off and I coasted a block or so and it turned on, no weird noises no complaints just smooth sailing back on home. scared me though...pics and vids on request
This post has been edited by Neon90424: Jun 17, 2011 - 5:59 PM
post Jun 18, 2011 - 9:11 PM
Neon90424
Joined Jan 19, '11
I think that the oil catch can I bought is a bottleneck to my car since today I had the fun experience of having the oil from the dipstick squirt out at 15 psi allover my windshield! big smoke cloud...
1 question, if under 10-15 psi of boost should my breather issue a faint blue smoke? every time...my piston rings are gone arent they?
post Jun 19, 2011 - 1:03 PM
Neon90424
Joined Jan 19, '11
http://www.youtube.com/watch?v=YKYdqKrgLxA
here's a vid of the bee-r launch control with the exhaust thru muffler and thru cut out
This post has been edited by Neon90424: Jun 19, 2011 - 1:06 PM
post Jun 20, 2011 - 9:41 AM
delusionz
Joined Feb 11, '08
you definitely need to do a run with a wideband kit to see where your leaning out (with that turbo im sure you will lean out over 15psi) and add water bit by bit until the engine feels the best (like on my setup i can feel when it leans out and pulls the timing)
from what i can gather, most turbos same size and bigger than stock they dont start pushing more air than stock until the higher psi range, so under stock boost it should be fairly stoich, so i guess you could hold off on the water until maybe 8 or 10psi
Mike W
269awhp / 273ft-lbs
post Jun 20, 2011 - 11:07 AM
Neon90424
Joined Jan 19, '11
yeah I figure i should buy a wideband with gauge kit off ebay cuz i have no ideawhere i am with the factory sensor
I Installed a FCD but havent gotten around to setting it right because I cant even reach fuel cut with my problems now...
I bought an AEM UEGO BOSCH OXYGEN WIDEBAND SENSOR off ebay for like 40$ I hope it works and I bought a 60mm gauge it should be here by next week or so my current distributor wire is causing mayhem on my top end so I cant really even boost past 7 or 8 psi without it going berserk.
Got new wheels smile.gif Advan Replicas ofcourse...
This post has been edited by Neon90424: Jun 20, 2011 - 4:15 PM
post Jun 21, 2011 - 9:11 PM
Neon90424
Joined Jan 19, '11
Well I have ordered new cables, tomorrow I am ordering new brake pads, and as to the smoke from the breather lines I am convinced (havent done a compression test yet tho) that the blow by is being caused by the synthetic oil I put in, will put in an additive to make it a bit thicker and see what happens. As the turbo part Is over I guess this can be moved into the PROJECT section (if any mods, or any one, is reading this[im pretty sure some guys want my car to burst into flames with me in it])
My rear diff mount is dead so that will be changed, my 25mm spacers are too wide and I will have them machined so that the wheels may actually fit inside the fenders. rotors will be resurfaced and new hawk pads are coming, new sparkplug cables and distributor cap on its way so I dont lose any lightning in high revs... BTW
I put in 5 liters of E85 (Alcohol and 15% gas) into my W.I. and the spray opens at about 3-4 psi But i still get that butt dyno feeling where It just kinda stops pulling on the high end...around 13 or so psi...ofcourse I shall tune accordingly with the FCD once the repairs are done ( new suspension should arrive...ahemm.. MUST arrive next week...it will be like christmas in july smile.gif
post Jun 23, 2011 - 7:49 PM
Neon90424
Joined Jan 19, '11
Here's a vid hitting fuel cut in second gear...
http://www.youtube.com/watch?v=0mbwwG4jROo
post Jun 25, 2011 - 11:23 AM
Neon90424
Joined Jan 19, '11
I just removed fuel cut and even boosted up to 23.1 psi, my breather tubes spewed oil is this normal? allover the place My rings are shot arent they? Im going to buy forged pistons and just get this **** over with.
post Jun 25, 2011 - 8:36 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
QUOTE (Neon90424 @ Jun 25, 2011 - 12:23 PM) *
sound like rings are shot, and the blow by is forcing the oil out the breathers, but do a compression test just to be sure.
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Jun 26, 2011 - 9:09 AM
you cracked a ringland, prolly in #2 or 3, thats why your spitting oil all over the place.
2 step (the BeeR) is murder on stock pistons, wouldnt doubt that being the cause, if not the overboost with the larger turbo.
post Jun 26, 2011 - 9:25 AM
Neon90424
Joined Jan 19, '11
thanks for the input guys Is my car driveable in NA (no boost) I dont want to tow it...
I am going to buy forged rods and pistons I am going for the CP / Eagle combo for 775$
an ARP bolt set and a headgasket set probably any suggestions guys?
Im gettin my list together
basically its a
Complete gasket set
Forged Eagles Forged CP pistons
ARP Headbolt set
750cc matched injectors
power FC and commander
Walbro 255
This post has been edited by Neon90424: Jun 26, 2011 - 9:43 AM
post Jun 26, 2011 - 9:46 AM
Neon90424
Joined Jan 19, '11
Its going to be about 4400$ to get all this in and have the car re finished/detailed so it should come out brand spankin new at 400-450 horsepower
Car runs fine im drivin it down to the mechanic
This post has been edited by Neon90424: Jun 26, 2011 - 2:08 PM
post Jun 26, 2011 - 4:48 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Build isnt starting to seem so cheap anymore lol...good to see you are going down a better route...man this thread should be a sticky....btw, might i ask why you are going with the PFC, and not something else...Also, where are you buying your pistons/rods from...i hear that on ebay they are usually stupid cheap..
(\__/)
Lo-Fi Version Time is now: November 23rd, 2024 - 11:07 PM
