15 Pages V  « < 6 7 8 9 10 > »
> GT-FOUR El Franjeado, EFR turbo etcq
post Aug 27, 2011 - 9:41 PM
Neon90424
Joined Jan 19, '11
thanks for the input guys really appreciate it.
post Aug 28, 2011 - 3:22 AM
Nial
Joined Aug 25, '08
From England
Loving the car and the "budget" build.
Did you find the answer to the water loss? Could be almost anything really, from a busted pipe to leaky head gasket. Have you checked the torque on the head bolts...when rebuilding an engine I always recheck the torque a couple of times until running in is complete!
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Aug 28, 2011 - 5:17 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
i also proved the EFR 6758 about he fit the 3S-GTE, just in front of the maps he will do a perfect job, in front of the material i'am sure that it is a
very good turbo and should kick any garett unit, i just found two issues
the one issue i have is that the twin entry's are currently not available for the small series B1 frame, i'am
told from borg warner that there is no release date yet but i will try it in the begining of the next year again
the other issue that i'am in need of a special version of a adapter becouse i use a corolla wrc manifold which relocate the turbo around 10cm, so it becomes
not so easy to get the IC fit
greetz
This post has been edited by Sunny: Aug 28, 2011 - 5:18 AM
KEEP COOL UNDER PRESSURE
post Aug 28, 2011 - 9:02 AM
Neon90424
Joined Jan 19, '11
I got a t25 manifold from ebay and hopefully it should fit with the turbo the kkr was a pain because we couldnt clock it well with the internal wg but this one says it has some voodoo magic that helps
My hg is also prbably busted as well...I hope its just the torque on the bolts...
yeah the Budget build went out the window when the stock ecu couldnt keep up...
This post has been edited by Neon90424: Aug 28, 2011 - 3:42 PM
post Aug 29, 2011 - 10:15 PM
Neon90424
Joined Jan 19, '11
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUCK SHIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIT AAAAAAAAASSS SANDWICHHH MOTHERRRRRRRFJUR#!(*$@!+(!$@(+!@(&~~~~~~~
my engine seized!, i wasnt even driving hard left home and after 5 friggin minutes car stopped made no noise and apparently seized, towed it to the mechanic and the timing belt snapped and the crank wont budge at all...any ideas why? I hope I can save the pistons and rods and bearings...I need a new 3s block..
Mechanic said "That because the turbo went that Driving it Na like forced the engine to much, overheated it once and kept heating it and that caused it to seize"...I had no water in my oil...
I'm so pissed right now...Btw the borg warner efr 6758 is on its way...I have to find a 3s block pronto
post Aug 29, 2011 - 11:32 PM
matts94celica
Joined Apr 20, '11
From College Station, Tx
Sorry for the loss bro, hopefully you can find another 3s block. Good luck & nice thread btw.
post Aug 30, 2011 - 6:20 PM
Neon90424
Joined Jan 19, '11
found a complete 3sgte 96-99 no tranny with w2a turbo etc for 2000$ down here and will buy...also splurged and you guys will like to hear this part...kind of
dna Cam Gears
Brian Crower stage 2 valves springs ti retainers and 264 camshafts
clear projector head lights
Flywheel
heat wrap
whole lotta stuff
This post has been edited by Neon90424: Aug 30, 2011 - 8:01 PM
post Sep 1, 2011 - 7:10 AM
Neon90424
Joined Jan 19, '11
good news, engine didnt seize the timing belt and its tensioner snapped and wrapped around it and that was what stopped the crank from moving. the engine is completely fine.
post Sep 1, 2011 - 4:03 PM
Nial
Joined Aug 25, '08
From England
Lucky...kind of....at least the engines OK...did you by the second engine?
post Sep 2, 2011 - 9:45 AM
Neon90424
Joined Jan 19, '11
I bought it but returned it, I have a kinda urgent question guys apparently i have 272 cams coming and dont know if I have to do the shimless or shimunder bucket conversion! I spoke to a guy down here and he said he didnt do it he has a 4th gen caldina and works fine...
any clarifications??
post Sep 3, 2011 - 12:46 AM
Culpable04
Joined Apr 17, '06
From New Jersey
you will need to grind a little bit on the head to allow the cam to fully rotate, but no shimless conversion needed for you.
the grinding that is needed can be done with sand paper, it's barely 1 oe 2 mm and it doesn't affect anything, once the cam is bolted in place, and you try to rotate it you will see exactly where it hits. very easy to do.
post Sep 3, 2011 - 9:13 AM
Neon90424
Joined Jan 19, '11
thanks man I appreciate it! I will check into that!
post Sep 6, 2011 - 5:01 PM
Neon90424
Joined Jan 19, '11
manifold came for 2nd gen...Found a 3rd gen manifold plate in UK and ordered it...
This post has been edited by Neon90424: Sep 10, 2011 - 5:58 PM
post Sep 10, 2011 - 5:59 PM
Neon90424
Joined Jan 19, '11
0075 090911 2011-09-09 FIBERGLASS EXHAUST HEADER WRAP
0084 090911 2011-09-09 COOLING SYSTEM WATER WETTER
0086 090911 2011-09-09 TIMING BELT COVER
0322 090911 2011-09-09 TOYOTA THERMOSTAT
0414 090911 2011-09-09 CARBON FIBER CLOTH BLUE
0419 090911 2011-09-09 TIMING BELT KIT TOYOTA
0435 090911 2011-09-09 UNIVERSAL TRIPLE GAUGE POD
0526 090911 2011-09-09 TOYOTA CELICA HEADLIGHTS
0528 090911 2011-09-09 TOYOTA FILTERS
0544 090911 2011-09-09 KNOB
0546 090911 2011-09-09 FLYWHEEL
0562 090911 2011-09-09 OIL COOLER KITS
0570 090911 2011-09-09 CARBON FIBER
0576 090911 2011-09-09 CELICA HOSE
0597 090911 2011-09-09 GASKET
smile.gif full of JDM WIN on the way!
This post has been edited by Neon90424: Sep 10, 2011 - 6:00 PM
post Sep 13, 2011 - 7:31 PM
matts94celica
Joined Apr 20, '11
You start getting parts in yet neon? Hopefully you can get it back up and running painlessly
post Sep 13, 2011 - 9:11 PM
Neon90424
Joined Jan 19, '11
I picked the parts up today!
Thermostat = 2nd gen
timing belt cover = 2nd gen mr2 (will modify it)
my Recaro knock offs weighing 37 kilograms = 650$ worth of shipping = twice of what I payed for the pair of seats, are in miami and about to ship..
Still waiting for the brian crower goodies to get my head put together and my friend left yesterday to chile I hope he can smuggle the Power FC out and back to me biggrin.gif!
The oil cooler kit is really nice and love its filter relocation kit has 2 sensor holes for the oil temp and press!
oh and...I WANT MY EFRRRRRRRRRRRRRRRRRRRRRR RAWRRRRRRRRRRR! I got the OBX stainless header and ordered a few vband flange kits to turn my exhaust into vband fun and non leaking old bent pos exhaust!
the trd CF knob...no idea how to put it on!
post Sep 16, 2011 - 10:10 PM
Neon90424
Joined Jan 19, '11
0740 091611 2011-09-16 BOSCH WIPER
0743 091611 2011-09-16 RACING FANS
0784 091611 2011-09-16 VALVESPRINGS RETAINERS
0785 091611 2011-09-16 VALVESPRINGS RETAINERS
0787 091611 2011-09-16 VALVESPRINGS RETAINERS
0800 091611 2011-09-16 AUTO PART
0807 091611 2011-09-16 TOYOTA STUDS
post Sep 18, 2011 - 10:09 AM
bsamps4
Joined May 16, '10
From Raleigh
I'm confused...How did it seize? "Driving it NA like" doesn't make any sense....???
post Sep 18, 2011 - 10:18 AM
Neon90424
Joined Jan 19, '11
It didnt seize, the timing belt snapped and it wrapped around the tensioner and wouldnt let me crank the engine...a fake seize I guess, I was driving it NA kinda because the max boost I got was 1 psi because its internal wastegate was rattle to **** open by launch control therefore giving me 0 spool whatsoever making me believe I shot the turbo but it was just that stupid detail...
post Oct 22, 2011 - 8:52 AM
Neon90424
Joined Jan 19, '11
This thread is about to become ALIVEEE again Updates starting tuesday! lotta pics as soon as my new camera comes in! apparently the thermostat was getting stuck which caused the overheating... Fidanza cam gears arrive on tuesday so hopefully the head will be sent to be machined and put together! still no idea on when i get my PFC tho I might have to work with the stock ECU on 272 cams and stock injectors...hmmmm
Lo-Fi Version Time is now: April 24th, 2025 - 1:21 PM
