15 Pages V  « < 11 12 13 14 15 >
> GT-FOUR El Franjeado, EFR turbo etcq
post Mar 10, 2012 - 3:08 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
I just noticed you had overheating issues, I got them too.. After replacing every cooling component, we pulled apart my engine to find the block and head surfaces weren't level (warped) ;\
my engine is being rebuilt, hopefully my luck isnt as bad as yours lol
Mike W
269awhp / 273ft-lbs
post Mar 10, 2012 - 4:36 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
thanks for the information
i think this is the correct URL
http://www.lithiatoyotaparts.com/partlocat...m?siteid=215542
greetz
KEEP COOL UNDER PRESSURE
post Mar 11, 2012 - 6:31 PM
Neon90424
Joined Jan 19, '11
thanks sunny, that sucks mike, my block was machined by a very professional place so they checked all that...the head was also machined so it shouldnt be a problem now... looking forward to updates on ur gt4!!
post Mar 16, 2012 - 3:27 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Surprised there hasnt been an update yet on the progress of things......Hmmm, so you finally get your car back together and started back up again ^_^
(\__/)
post Mar 16, 2012 - 5:41 PM
Neon90424
Joined Jan 19, '11
post Mar 17, 2012 - 12:17 AM
3WayStunna
Joined Jun 25, '06
(\__/)
post Mar 17, 2012 - 5:32 AM
Neon90424
Joined Jan 19, '11
Yeah it came out pretty nice on camera biggrin.gif took TRDGT4's valve cover as inspiration
post Mar 18, 2012 - 6:16 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
do not forget to paint the japanese war flag on the intercooler -> another 10hp biggrin.gif
http://www.amazon.de/GROSSE-Japanische-Kri...e/dp/B001DUWZAO
greetz
post Mar 18, 2012 - 8:19 AM
Neon90424
Joined Jan 19, '11
hahaha my intercooler is staying Cusco Blue, but the C-One panel will have a tiny japanese war flag on it smile.gif I believe about 20 hp in total is gained. plus 99 experience points.
post Apr 1, 2012 - 7:35 AM
Neon90424
Joined Jan 19, '11
i have been using the car for the last 2 days, bought an optima yellow battery, But my car seems to have a short circuit somewhere...my intercooler and battery another light are on and the alternator wont charge, but last night it got to 16.9v idling everything started flickering so I killed it...we checked all fuses yesterday so I cant understand if my alt is dead or what
post Apr 6, 2012 - 10:05 PM
Neon90424
Joined Jan 19, '11
it was just the voltage regulator and pretty much everything that hooks up in the back of the alternator that got fried. I have a small oil leak from a hose and my dash is being removed to be repaired on monday...
post May 17, 2012 - 7:17 AM
Neon90424
Joined Jan 19, '11
almost there guys biggrin.gif new Fuel system and the dash has been remade
post Jun 25, 2012 - 9:22 AM
Neon90424
Joined Jan 19, '11
raced the car yesterday had a bunch of problems... mostly from a loose ground on the dist. coil, I was disqualified after fixing my problem, but i have exhaust leak and a few other problems, spark plugs etc I have to fix...the boost controller didn't seem to work so I ended up unplugging the internal boost controller can thingy... I got 1.5 Bar tops around 5k...needs more tuning etc.
no one reads this anyways.
post Jun 25, 2012 - 9:41 AM
bsamps4
Joined May 16, '10
From Raleigh
I read it.
post Jun 25, 2012 - 12:18 PM
3WayStunna
Joined Jun 25, '06
(\__/)
post Jun 25, 2012 - 12:58 PM
Neon90424
Joined Jan 19, '11
I use to post alot but things kinda slowed down... Going to merge the SS manifold and SS exhaust part of the EFR, so as to not lose any boost and buy an OBX vband wastegate that I can hopefully also weld onto the mani because its really tight on space... iridium heat range 9 spark plugs, the fuel system has to be installed as does the nitrous and tuning the car...alot and the next race is a month away.
post Jun 25, 2012 - 1:02 PM
cheela
Joined Feb 2, '07
From Berlin, WI
i read too yo. keep it up man.
post Jun 25, 2012 - 1:04 PM
Neon90424
Joined Jan 19, '11
i owe you guys a pic with the drag slicks... i hope they are up today.
post Jun 25, 2012 - 1:48 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I read this whenever theres updates
94 st hatch my daily driver
n
post Jun 25, 2012 - 2:21 PM
Neon90424
Joined Jan 19, '11
complete mess
trying to fix the misfire
trying to tighten the wastegate nuts but they were tights, so we just unhooked the damn thing
an embarrasing 9.6 sec 1/8 mile with the car stuttering and untuned...
a toy at the party
and after the car exploded at the starting line like it had launch control I realized it was the god damn coil grounding that was shot to **** because it was held by a single bolt
Lo-Fi Version Time is now: November 24th, 2024 - 12:58 AM
