Diagnosing ABS trouble codes |
Jan 20, 2011 - 2:43 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
This link shown will have most of the info you need to diagnose and fix your abs trouble codes. As well as clearing the ABS codes.
http://www.autoshop101.com/forms/brake10.pdf Pretty much the same run through as getting CEL or DTC engine codes. You bridge the Tc and E1 terminals on your Diagnosis box with a paper clip and switch your ignition to the "ON" position. Count the number of flashes and pauses, these will give you the number codes. Ex. "Flash, Flash, Flash....Pause....Flash, Flash, Flash (LONG PAUSE) Then code repeats" This will give you Code 33 which means your Rear Right ABS sensor has a signal malfunction, either loose connection or some wires were damaged during some kind of job in that area like changing shocks. Although the link shows mostly RAv4's and Camry's im sure its the same stuff across the family tree P/N for your abs needs for 6th gens 88263A RELAY, SKID CONTROL 88263-14110 AT200, ST204; NO.1 (10/1995 - 07/1999) 1 $81.33 88263-24020 AT200, ST204; NO.1 (09/1993 - 07/1995) 1 $56.90 88263-24030 AT200, ST204; NO.2 1 $59.46 88267 BRACKET, SKID CONTROL COMPUTER, NO.1 88267-20150 AT200, ST204 (09/1993 - 07/1995) 1 $10.06 88267-20170 AT200, ST204 (10/1995 - 07/1999) 1 $6.08 88268 BRACKET, SKID CONTROL COMPUTER, NO.2 88268-20130 AT200, ST204 (09/1993 - 07/1995) 1 $13.86 88268-20150 AT200, ST204 (10/1995 - 07/1999) 1 $12.53 89540 COMPUTER ASSY, SKID CONTROL 89541-20130 AT200, ST204 (09/1993 - 07/1995) 1 $659.27 89541-20160 AT200, ST204 (10/1995 - 11/1997) 1 $378.19 89542 SENSOR, SPEED, FRONT RH 89542-20090 AT200, ST204 (09/1993 - 07/1995) 1 $264.41 89542-20110 AT200, ST204 (10/1995 - 07/1999) 1 $240.15 89543 SENSOR, SPEED, FRONT LH 89543-20090 AT200, ST204 (09/1993 - 07/1995) 1 $264.41 89543-20110 AT200, ST204 (10/1995 - 07/1999) 1 $240.15 89545 SENSOR, SPEED, REAR RH 89545-20090 AT200, ST204 (09/1993 - 07/1995) 1 $264.41 89545-20120 AT200, ST204 (10/1995 - 07/1999) 1 $240.15 89546 SENSOR, SPEED, REAR LH 89546-20090 AT200, ST204 (09/1993 - 07/1995) 1 $264.41 89546-20120 AT200, ST204 (10/1995 - 07/1999) 1 $240.15 Called Toyota today and the prices are close to what ToyoDIY has them posted for. I guess it depends on your location This post has been edited by 808celica: Jan 20, 2011 - 2:54 AM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Lo-Fi Version | Time is now: December 3rd, 2024 - 10:09 PM |
