P0325 OBD-II Trouble Code, Knock Sensor 1 Circuit |
Jan 21, 2011 - 1:49 AM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
Hey dudes,
I got an CEL, and after resetting the ECU it still came right back. The guys at the mechanic shop wanted 50 bucks just to read the code! I said screw that, went on ebay and got a usb code reader for 15 buck shipped. Hahaha. Anyway, I plugged it in (I switched the "baud rate" to 38400, otherwise it didn't work) and it spit out the code "P0325, Knock Sensor 1 Circuit." I'm thinking that maybe recently when I was changing the oil I spilled some on the sensor and shorted it... Does this sound right? Anyway, I was wondering if someone can tell me where exactly the knock sensor is on the 7afe, and if it is difficult to replace? Thanks a bunch! |
Jan 21, 2011 - 8:02 AM |
its between cylinders 3&4, in back of the engine, on the upper half of the block.
IIRC its a 24mm socket -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jan 21, 2011 - 3:17 PM |
Thanks man you rock
Lo-Fi Version | Time is now: January 9th, 2025 - 6:32 AM |
