WTB: 94 GT st204 left front wheel assembly, had some problems, need parts |
Jan 25, 2011 - 3:30 PM |
Enthusiast Joined Jan 7, '11 From Mena, AR Currently Offline Reputation: 0 (0%) |
i need the ENTIRE LEFT wheel assembly to a 94 GT. steering knuckle, wheel bearing, brake system, hub, basically everything between the transmission and the wheel but the CV axle and strut
This post has been edited by playboymma: Jan 25, 2011 - 3:30 PM -------------------- I went full retard once, too. Its OK.
Jan 26, 2011 - 9:06 AM |
Enthusiast Joined Oct 22, '08 From Eden, NC Currently Offline Reputation: 0 (0%) |
I got the entire left wheel assembly in tact off of a 95 gt, would you mind listing exactly which parts you need and we can see what we can do. Located in central northern NC.
Jan 26, 2011 - 5:56 PM |
I got the entire left wheel assembly in tact off of a 95 gt, would you mind listing exactly which parts you need and we can see what we can do. Located in central northern NC. i actually dont need the left just yet but i pulled the whole thing apart for a closer look and the whole hub is TOAST. so i just need the hub. the wheel bearing was still under warranty so i will only have to replace the RIGHT front hub and then look at the left side. its still solid but i dont like just replacing a part without replacing its twin. kinda like only replacing the brake rotor on one corner -------------------- I went full retard once, too. Its OK.
Lo-Fi Version | Time is now: November 26th, 2024 - 2:36 AM |
